Vibration/Grind when warm
Old Feb 10, 2013 | 01:48 PM
scottf4444's Avatar
scottf4444
Need some help here please...vehicle info below in sig. After driving for about 15 minutes, once it is warmed up, at acceleration & low rpm's, there is a vibration, mild grinding noise. Once you get to mid-range and up on the rpm's, it goes away. When cruising down the highway at normal speeds and a consistant rpm...no noise. Idling at, and taking off from a stop light, I get the noise. The longer it is driven, the more noticeable the noise is. Possible torque converter???
scottf4444
Feb 15, 2013 05:56 PM
deadbear
Apr 4, 2007 09:07 AM
superpelly
Nov 26, 2006 10:30 AM
ercaraker
May 7, 2006 11:02 AM
