Tranny flush or not ?
It's time for my 30,000 mi. tranny service and I want some opinions on what I should do. I am undecided whether to change the external filter and do a couple of drain & refills myself or to have a dealer do a hot flush. My local dealer who I trust does not have a hot flush machine and I have heard some horror stories from the other dealers close by so I am a little uneasy about letting them work on my truck. When possible,I prefer to do things myself so I know it's done right. Is it OK to do a couple or 3 drain/refills myself ? (personally I think it would prob. take 3 to get all the old fluid out but what do you think) Should I change the external filter on the first drain/refill or the last,or would it be necessary to change the filter every time? (I wouldn't think so but I'm just asking) Thanks for the opinions and,as always,thanks in advance!!
Spill, replace external filter, swap in 6.4L pan and internal filter, fill. Spill and fill every 15k from now on if you're really beating on it.
The 6.4L internal filter is a lot larger and more effective, unless you're tuned or really heating/overheating the trans while towing spilling the fluid and doing the external filter every 30k should be fine.
The thing is, in order to open up the transcooler, I think the tranny has to hit 170 degrees to start circulation, maybe even 180. So, I think a single change, followed by some heavy pulling for an hour or more would be required before the second drain and filter. Then I would just do it every 30k miles once. Mercon SP is not cheap. Frankly when I changed mine last time and got it flushed, you could not tell the difference in the oil, it was the same colour and same viscosity. Maybe an oil analysis would be required to show the difference. So, your thoughts may vary but I think a single change every 30k, a filter every 60 without flush or a full flush every 60 would be fine for most.
Thanks for all the help! So it sounds like everybody feels like a single drain & refill and an external filter change now and then again in 15,000 more mi. is good? Is the 6.4L pan & filter a direct swap without mods? Is it that much better than the pan/filter we have now? Sorry for all the questions but thanks again!!
I also only use Mercon SP.
