parking lights
Old Feb 10, 2013 | 10:45 AM
riverguideguy's Avatar
riverguideguy
parking lights
i have one front parking light thats very bright and the other side is very dim. i tried 4 diffrent new bulbs with no difference. what would cause this? thanx
Old Feb 10, 2013 | 11:05 AM
TexasTrash's Avatar
TexasTrash
Just a thought, but is the one lens cloudy, causing it to look dimmer?
Old Feb 10, 2013 | 11:32 AM
79f250_ranger_xlt's Avatar
79f250_ranger_xlt
sounds like one socket was replaced & hooked up backwards
Old Feb 10, 2013 | 11:51 AM
fmc400's Avatar
fmc400
MSEE
Or the socket is bad to begin with. Given the fact that you tried 4 bulbs, it sounds like you desperately wanted the bulb to be the problem
Old Feb 10, 2013 | 12:03 PM
paredneck33's Avatar
paredneck33
look at the ground wires. sounds like a ground issue to me. check for looseness, corrosion either on a terminal, wire, or inside the socket.
Old Feb 10, 2013 | 01:33 PM
montana_highboy's Avatar
montana_highboy
Bulb in backwards?
They're supossed to only fit one way but the tolerance in the socket isn't exact, allowing for a bulb to be installed backwards if slightly forced.
Old Feb 10, 2013 | 05:41 PM
riverguideguy
winner winner chicken dinner! that was the problem. i pulled the lights again and seen the socket spliced in to the wiring with electrical tape switched the wires around and now both sides are bright. thanx
Old Feb 10, 2013 | 07:34 PM
fmc400's Avatar
fmc400
MSEE
Glad to hear you got it worked out - but now that you know what's up, you should go back over the connection and do it properly with solder and shrink wrap (as opposed to electrical tape).
Old Feb 10, 2013 | 09:31 PM
crownver's Avatar
crownver
Actually, the parking lights should be the dimmer light, and turn signals brighter. Maybe they're both wired wrong now?
Old Feb 10, 2013 | 09:48 PM
earthquake68's Avatar
earthquake68
That's what jumped into my head when I read it. They should both be DIM with the just parking lights on.
joninflorida
Feb 14, 2019 12:52 PM
Nighteyez
1978 - 1996 Big Bronco
18
Dec 20, 2011 09:35 PM
weyland426
Feb 11, 2010 04:04 PM
inline6 Red Neck
Electrical Systems/Wiring
Jul 3, 2006 08:00 PM
kman2785
May 4, 2003 06:24 PM
