Trans question
Old Feb 10, 2013 | 05:55 AM
A-Z Racing's Avatar
A-Z Racing
Trans question
OK, my mechanic's helper did a water pump chance out on my 2000 F-250 7.3, damaged my two year old solid aluminum tank radiator because he did not remove it and punctured it with the fan blade, good news is he replaced it with a plastic tank unit, bad news is he forgot to replace my trans fluid that leaked out with the removal of old radiator. The question is i drove 100 miles on highway with low fluid, i have installed 5 qts of fluid to get it on dipstick. Could i have hurt trans? Should i do a complete fluid change in case i over heated the fluid that was low?
Old Feb 10, 2013 | 08:16 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
My guess is that you have overfilled it. I don't think the trans will operate 5 quarts low. Before doing anything else recheck the fluid. I doubt you hurt anything being over or under filled.
Old Feb 10, 2013 | 04:57 PM
A-Z Racing's Avatar
A-Z Racing
No still not overfilled, i have put 4.75 quarts in it . Ran today for 10 miles and is probably still 1/2 qt. low checking while hot with motor running. I'm surprised it moved at all ,thats why i'm worried about trans.
Old Feb 11, 2013 | 06:18 AM
stuart1's Avatar
stuart1
I can't see 5 quarts running out of a cooler. It must have been low to start with.
Old Feb 11, 2013 | 12:06 PM
A-Z Racing's Avatar
A-Z Racing
I don't think it was low at all, i do know how much i put back in. Wouldn't the disconnected lines gravity leak down some of the fluid from the trans?
Old Feb 11, 2013 | 02:13 PM
fasthauler's Avatar
fasthauler
This is really strange because I did a flow check on my C6 a year ago. I was checking to see how long it would take to move 4 quarts through the system and the tranny quit pumping after 3 ½ quarts and it definitely wont move if its not pumping. I do not doubt your word, but it does seem strange. I would check your dipstick tube to make sure it hasn’t popped part way out of the transmission causing the dipstick not to go all the way down. Other than that I don’t see where running low for that short of distance would damage the tranny. The only thing that might happen is picking up some crud off of the bottom of the pan and sucking it into the valve body. As far as the fluid leaking out through gravity. I don’t think much will come out if its not pumping. I think I would just change the fluid and count how many quarts it takes to get it to the full line. Be sure and drain the converter as well as the pan. These C6 trannys are really rugged and I doubt it got hurt.
Old Feb 11, 2013 | 02:33 PM
stuart1's Avatar
stuart1
Just what was in the lines.
Old Feb 11, 2013 | 02:43 PM
A-Z Racing's Avatar
A-Z Racing
OK, how much does radiator cooler hold? I'm starting to think rookie helper at mechanic shop started motor with lines disconnected. Made 100 mile round trip today on and off highway and it seems fine. I still think i'm going to replace all fluid anyways just to be safe in case i overheated the low fluid.
Old Feb 11, 2013 | 02:48 PM
stuart1's Avatar
stuart1
The cooler would hold about 1 pint.
For sleep insurance drop the pan.
Old Feb 11, 2013 | 06:28 PM
A-Z Racing's Avatar
A-Z Racing
Yea that's the plan in a couple of days...
LKCKR
2004 - 2008 F150
Nov 29, 2021 11:19 PM
69ford99
1997 - 2003 F150
Sep 20, 2017 06:26 AM
gilm1952
Modular V8 (4.6L, 5.4L)
Feb 6, 2016 07:01 AM
Dieseldriver13
Feb 26, 2013 07:46 AM
superduty lee
Modular V10 (6.8l)
Nov 14, 2006 01:47 PM
