transmission fluid quantities
Old 02-10-2013, 05:43 AM
alchemist1's Avatar
alchemist1
alchemist1 is offline
Approximately how much transmission fluid does the pan hold, for a C6 (1974). I basically drained it and just need an approximate. Thinking 3-4 quarts?
thanks
Old 02-10-2013, 06:04 AM
jim collins's Avatar
jim collins
jim collins is offline
If you never drained the t-converter you might start out with four, then keep adding until it's full. It probably holds about 12 to 14 if the t-converter was drained. I believe my AOD was 13.5 with a new t-converter.You need the trany warmed up good and check it at idle in park.
Old 02-10-2013, 09:11 AM
alchemist1's Avatar
alchemist1
Nope, TC wasn't drained. Just replaced the vacuum modulator and fluid drained out of that hole, which is at bottom of casing, but not quite to the pan.
Thanks.
1981 F100
11-21-2018 06:26 AM
bc4x4f250
06-15-2014 06:07 AM
Eddyo
09-16-2011 07:22 PM
BrianA
03-13-2006 01:02 PM
Sardu
1983 - 2012 Ranger & B-Series
01-30-2005 09:11 PM
Quick Reply: transmission fluid quantities
