Sure why not.
You may also want to get some new adjustable camber bushings so that afterwards you can get the truck realigned. If the alignment shop does it you'll spend 2x what it should really cost.
I'd go with those instead of a block. You may want new ubolts depending on if you need to use heat to get yours undone.
