Sponsored by: Real Truck
Do I need alignment cams with a leveling kit?
Old Jul 7, 2005 | 10:29 PM
tporter's Avatar
tporter
I am buying a leveling kit for my 05 F250. Do I need to buy alignment cams with my kit?
Old Jul 8, 2005 | 07:47 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
Moved and member notifed
Old Jul 8, 2005 | 10:52 AM
RocketScience's Avatar
RocketScience
I would assume a 'kit' would come with everything you need to get the job done.
On my '02, I used the Tuff Country 2.5" leveling kit shown here http://www.tuffcountry.com/suspension_ford_SD.html.
Your truck however has coils and would use a kit probably similar to the one shown here http://www.tuffcountry.com/suspension_ford_SD05.html (which I do not see any type of leveling/adjustment 'cam' included).
One other piece of advice I'd like to pass on. These 'Leveling Kits' are set up to level the geometry of the worst case scenario wheelbase (i.e. long box, crew cab). If your truck happens to be like mine, short box, SC, then you may need to adjust the rear suspension to compensate (add-a-leaf, re-arc the springs, or lift block) or your truck will be going down the road with a 'nose up' attitude.
EDIT: I'm assuming your truck is a 4X4.
Old Aug 5, 2005 | 11:28 PM
El Gato's Avatar
El Gato
These cams really do work; however, alignment shops charge between 50-100 bones to install. I would buy mine from a distributor or auto parts store and have them intall it. It does not take long to install.
Old Aug 6, 2005 | 12:08 AM
MAXEY's Avatar
MAXEY
remember the kits dont allways come with everything you need make sure you got it all on hand before you dig in unless you got another ride
