GPR going out
Old Feb 16, 2013 | 08:58 PM
petrokiller's Avatar
petrokiller
I just put in a Napa GPR109 a few weeks ago.
Those Stancor's look to tall for my stock wire length.
Does everyone have no problem with wire length???
Old Feb 17, 2013 | 03:26 PM
99StrokeXLT's Avatar
99StrokeXLT
The wires work out just fine as do the mounting studs. Search: White and Rodgers 586-105111 (same as a stancor). Let me know if you cannot find it.
Old Feb 18, 2013 | 08:50 PM
Turfzilla's Avatar
Turfzilla
I used the GPR 11 (Borg -Warner ) from orielys. Life time warranty.
Old Feb 19, 2013 | 10:26 AM
Brother Les's Avatar
Brother Les
GPR109 from NAPA 3year 36,000 mile warranty. First one went bad after two years, to it back, warranty starts over. 25.00$
Old Jan 21, 2014 | 10:10 AM
Cell's's Avatar
Cell's
I know this post is almost a year old but I thought I wouls share my story regarding putting in a Stancor 586-902 relay .
I had an issue with my truck and the starting romps when cold . I did lots of reading and decided to swap in a Stancor relay . That cured my pro lem for a little bit but then the no starts and the romps came back . I was chasing electrical issues , thinking that was the reason the truck wouldn't start because the relay was brand new . To make a long story short , I took my truck into a place for them to diagnose the problem . They eventually tested the relay and found the Stancor to be bad after only less than a years use . They put in an OEM relay and it's been good since then .
I decided to check into why the Stancor could have gone bad . After looking into the parameters of the Stancor ,
it says the relay is rated for -20 F .
It gets colder than that up here so I guess I know now why it didn't last long for me .
Just my .02 cents .
Old Jan 21, 2014 | 12:06 PM
sledhead999's Avatar
sledhead999
Originally Posted by Cell's
If you don't mind ,,,,, can you guys give me the part# of the McMaster Carr relay that you ordered ??
I can't seem to find it on their website
Thank-you !
Here's a link to one of my older post with the McMaster-Carr part #.
https://www.ford-trucks.com/forums/1...l#post11636534
tim.g.tyler
6.2L V8
Oct 2, 2013 08:28 PM
Gibsonjork
May 8, 2013 09:36 AM
