block heater
Old Feb 9, 2013 | 11:05 AM
adamkat22's Avatar
adamkat22
block heater
maybe there is no generic answer for this, but i'm wondering how long you all normally plug your block heater in when using it? this is my first winter with this van, and i'm in upstate ny. probably averages 20 at night this winter. i feel like i used to plug it in just for 20 minutes and would be good but recently have been having to do it for an hour and the results still aren't awesome. is there a way to check it?
Old Feb 9, 2013 | 11:47 AM
jeffbradbury7's Avatar
jeffbradbury7
my 1991 takes 2 hrs at 40deg to get warm
Old Feb 9, 2013 | 11:52 AM
Sycostang67's Avatar
Sycostang67
You need about 2-3 hours to get it warm, these rigs hold a lot of coolant. The best solution is to have a timer that turns it on several hours before you need to use the vehicle. I plug mine in just before I go to bed at night. I plan on getting a timer eventually.
Old Feb 9, 2013 | 11:55 AM
Phy's Avatar
Phy
On mine, 20 minutes wouldn't do much. At 20º mine would take at least an hour or two. I like to be able to feel warmth at the valve cover...
I'm in the foothills outside of Denver, and plow snow in the winter. I often have to start up at 0º or below. I like to have it plugged if for several hours at those times...
Old Feb 9, 2013 | 02:28 PM
kc0stp's Avatar
kc0stp
At 20degrees you shouldnt need the heater so I would be checking the glow plugs, that said takes 2-3 hours without a lot of wind to warm it up.
Old Feb 9, 2013 | 06:13 PM
'94IDITurbo7.3's Avatar
'94IDITurbo7.3
hour for me and fires right up. i park in a garage though so that keeps the wind off the truck.
srqdiesel chef
Feb 7, 2009 12:59 PM
justice
Jan 3, 2008 08:13 PM
CPT_Diesel
16
Dec 10, 2007 05:17 PM
cbirdman
Feb 14, 2007 11:00 AM
Hangfire
Nov 27, 2004 11:48 PM
