Uhhhhhhh ohhhhhhh!
Old Feb 9, 2013 | 10:35 AM
AMEC Electric LLC's Avatar
AMEC Electric LLC
Uhhhhhhh ohhhhhhh!
The dreaded "water in fuel" indicator is on! I'm traveling an hour south of me in the blizzard and the WIF indicator goes on. I immediately pull over and crawl under the truck to find the wiring to the sensor disconnected!!!(I just had Ford service the vehicle Monday!) I plug it back in and no change. After 50 miles or so the truck goes into reduced power mode. I get home and ride out the storm. After cleaning up the snow I get under the truck and disconnect, clean, and re-install connector on the sensor. Drain fuel from bowl.....not a drop of water. Restart truck...still no change. I know theres no water but now what?
Old Feb 9, 2013 | 11:03 AM
Tim Young's Avatar
Tim Young
Active Streak: 30 Days
I'm not an expert yet, but my guess is that once the truck has set the WIF DTC code and went into reduced power it is going to have to be reset. You can pull the battery cables off for a bit and clear the codes. But that is not going to fix the problem. The truck should start and run fine until it sets the code again and that might be right away also. It sounds like the sensor has gone bad. Also pulling the battery cables also clears the freeze frame codes that Ford would like to see for trouble shooting the problem.
It's up to you if you need the truck this weekend pull the battery cable and try it if you can get buy without it take it back to Ford on Monday.
Hope that helps.
Cheers
Old Feb 9, 2013 | 12:01 PM
bridge's Avatar
bridge
Sick 'n Tired
I'd pull the battery cable(s), step on the brake to drain the system and see if it resets the code. Sounds like your WIF sensor got caked in snow and set the code. If it comes back take 'er to the dealer.
Old Feb 9, 2013 | 02:09 PM
rickatic's Avatar
rickatic
I sincerely hope you do not have a CP4 HPFP failure down the road...after my debacle, Ford made sure any WIF incidents were forever caught in the non-eraseable memory of the trucks computer...remember, they demanded that I proved I did not have a WIF light, all the time knowing there was no way to prove that point...now you will have to prove that you never had any water in your fuel when your truck swears that it did...
Good Luck
Regards
Old Feb 9, 2013 | 02:42 PM
CountryD's Avatar
CountryD
Subscribed. Hope this turns out ok. Good luck and let us know what happens.
Old Feb 9, 2013 | 03:42 PM
AMEC Electric LLC
Good Luck
Regards
I hope not! I called the dealer from the side of the road and gave the service manager a piece of my mind. I sealed the fuel I took out of the bowl this morning in a container just in case....not that it means anything. I'm wondering if the disconnected wiring causes a "sensor missing" or "sensor out-of-range" code first?
Old Feb 9, 2013 | 03:48 PM
Hdslider's Avatar
Hdslider
As soon as that wire came disconected. It sets a CEL. They may not haf it clipped on. Till snow pulled it off. Id go talk to service manager anf get it resolved.
Old Feb 9, 2013 | 03:59 PM
AMEC Electric LLC
The service advisor I spoke to this morning said the sensor does not set a CEL. The CEL never came on....just the WIF and REP indicators.
Old Feb 9, 2013 | 04:35 PM
senix's Avatar
senix
I'd change your fuel filters right now in addition to cleaning up the sensor.
Old Feb 9, 2013 | 04:38 PM
AMEC Electric LLC
Fuel filters just changed Monday. I'm not touching anything. As far as I'm concerned, they left it disconnected, its on them now
Old Feb 9, 2013 | 04:54 PM
rickatic's Avatar
rickatic
To the best of my recollection...any trucks that have been re-flashed after September 2010 have coding inserted into the non-erasable memory that retains a flag that the WIF indicator has been activated...
Unless Ford has changed it's policy, all HPFP failures require a FSE approval (or more likely,disapproval) before any repairs can be made under warranty. it will be tough to hide the WIF indicator evidence...especially if you are not fortunate enough to break down close to home...
Hopefully...you will never have to find out...
Regards
Old Feb 9, 2013 | 05:00 PM
AMEC Electric LLC
Regards
I already informed the dealer that I want it in writing or my lawyer will be contacting them.
Old Feb 9, 2013 | 07:21 PM
Tom's Avatar
Tom
Why the worry? The WIF indicator is mentioned in the owners manual, and under normal circumstances is a normal part of the way the truck is supposed to run. It simply indicates that the fuel/water separator is doing its job. Of course in this case it is completely meaningless. So why the worry?
But would it really matter Rick? I mean...there was no evidence that your WIF light ever came on and they still denied your warranty claim. Even if the WIF light never set do you think they would cover the repair if they determine there is evidence of water damage?
Old Feb 9, 2013 | 10:21 PM
rickatic's Avatar
rickatic
seriously...with the track record Ford has concerning HPFP failures and warranty coverage denials...a WIF warning locked into the computer will fly the red flag instantly
again...the record speaks for itself...Ford has a published policy regarding any HPFP failure...they needed no reason to not warranty my truck other than a dealership battle and politics...does anyone think Ford would fix anything they could weasel out of warranty coverage...and you are right...they would not fix any truck that shows even the smallest indicator of water infiltration...and they are still the only CP4 series pump user who does not fix their trucks...
Regards
Old Feb 10, 2013 | 08:10 AM
AMEC Electric LLC
Sorry Rick......had no intention of making you relive this.
