Distributor Question
Old Feb 8, 2013 | 07:14 PM
captradiator's Avatar
captradiator
FTE Family,
So, the tired, old 272 is out of my 1956 F-350 wrecker, and the 292 is being prepped to install. The distributor shaft is smaller, and shaped differently on the 272. The 292 was given to me, and is a Fred Jones rebuilt, supposedly from a 1957 Mercury. (I pulled it from a 1959 B-600.)
Sorry for the confusion. I have looked up rotors for both engines, and different part numbers are shown, as well as different numbers for a complete distributor.
Money is tight, but I do NOT want to make a mistake, so any input will be appreciated. I will look for part numbers on the two distributors tomorrow. (The truck is in a friend's shop, about ten miles from me.)
Thanks in advance,
Old Feb 8, 2013 | 09:35 PM
pintoplumber's Avatar
pintoplumber
The 54 239's and 256's had a tang drive for the distributor. It was a heavy shaft with like a screwdriver blade on each end. The 55 and up engines had a 5/16" hex drive. The 54's had a 13 tooth gear, the others have a 14 tooth gear. Dennis
Old Feb 9, 2013 | 07:51 AM
captradiator
Shaft
P.P,
Thanks for your response. To be more clear, it is the shaft end in the distributor that I am speaking of.
Old Feb 9, 2013 | 10:07 AM
pintoplumber
I'm still not clear. Are you looking inside the distributor, or is the distributor out and you are looking at the end of the shaft? If you are looking inside, the 57 and up distributors used a different cap and rotor. Dennis
Old Feb 9, 2013 | 04:32 PM
captradiator
Cap
Dennis,
Both distributors are still in the respective engines, so my concern is where the rotor mounts. You have answered my question, and I do appreciate it!
Old Feb 28, 2013 | 05:11 AM
big job's Avatar
big job
Opps did I see 1957 Mercury that would be only two offered, a 312 and
368. So I could be you are dealing with a 312 which looks the same.
Boundertom
18
Apr 16, 2020 09:11 PM
Blown 331
Jun 29, 2019 06:12 PM
Steves55
Aug 15, 2017 10:14 AM
john72ss
1983 - 2012 Ranger & B-Series
Jan 26, 2004 09:16 PM
Specter
Bronco II
Oct 14, 2003 05:44 PM
