51 Ford F1 truck (rear end/suspension swap)
Old 02-08-2013, 04:34 PM
51FordTN's Avatar
51FordTN
51FordTN is offline
I would like to change the rear end/suspension with something more highway friendly. I am limited on doing a lot of fabrication. The truck has a 312 Y block with a 4 speed t98 transmission. Any ideas are appreciated. Thank You.
Old 02-08-2013, 05:11 PM
51PanelMan's Avatar
51PanelMan
51PanelMan is offline
Ford 9" from a 1957-1972 F100 is pretty much a direct bolt on. You'll need larger rear shock brackets since the 9" housing is larger than the stock rear end housing. Stick rear shock brackets from a 1948-52 F2-F3 will also work. Summit also has a set of generic shock mounts that will work with the 9".
Old 02-08-2013, 05:14 PM
brain75's Avatar
brain75
brain75 is offline
assuming you are pretty stock:
for a 1/2 ton, you are looking at a 5 on 5 1/2 pattern
for a 51, you would need a 61" wide rear end. Great luck a Ford 9" from a 57-72 F100 truck is a direct bolt in, leaf spring pads are the same width and everything. on my 48 I have a slight difference in the shock mounts. I overcame this with a bolt change rather than grinding off and re-positioning the shock mounts.
Now if you want to switch to a 5 on 5 pattern or 5 on 4 1/2 then other 9" are also choices (5 on 4 1/2 is the "car" pattern 5 on 5 1/2 is the "truck" pattern). Early shoe box broncos (pre '72) I believe are also the same width.
There is a whole article on rear end options and I have written an xl spreadsheet with a great level of detail.
1948 through 1960 Ford F-1 and F-100 Rear Axle (differential) Swaps .: Articles
http://www.brainsbivouac.com/cars/19...20Database.xls
I also think a guy could use a Dana 44 from those same years (57-72) - early on when Ford got a request for a locker they used Dana instead of 9", later they offer the 9 with LSD of some type.
A lot of focus has been given to the 9" since it is well supported, but something I found because it is also associated with racing, there is a TON of price gouging when it comes to work. Offroaders generally go up to the DANA 60, and that leaves the 44 as a common (still being put in today), with lots of support and less $$$ hit.
Note, if you are taking a complete axle out from under a truck/bronco/mustang then I would strongly recommend you narrow your years - in '68 all brakes became dual circuit (law), there was a ton of changes and some of em not so good. in '69 Ford increased the brakes from the smaller width to a full 2". I would suggest look for a 69-72 F100. If you are going to a yard, find the best ratio, and cabbage parts off all the other donors to give it the best brakes possible and then buy the whole axle complete. Grab the u bolts and shackle plates since as mentioned the old is 2 1/2" the new is 3" tube.
I screwed up and got the newest best brakes in the wrong ratio - I am now looking for a center section swap.
Old 02-08-2013, 05:48 PM
rhopper's Avatar
rhopper
rhopper is offline
Along with making the engine happier, make yourself happier. While your making changes, how about softening the ride? There are softer leaf springs on the market, posies is one of the better ones. Removing leafs is also an option.
Old 02-10-2013, 10:15 PM
51FordTN's Avatar
51FordTN
51FordTN is offline
Front supension swap
Thank You for the GREAT information. Would you happen to have similar info for changing the front suspension as well? Thank You, Brian
Old 02-10-2013, 10:21 PM
brain75's Avatar
brain75
brain75 is offline
No can do mon ami, all the front end swaps turn into fab fab fab. I think about the simplest would be to use an early F100 or bronco front end (the dreaded twin i beam).... A better quality would be a later f100 or bronco (like a dana 44 if you want to go the route of the 4x4 land) - but again FAB FAB Fan-dab-ulous.
Others might have more ideas than what I threw out there but I don't remember seeing any threads about a simple front end swap.
If you aren't going to do a ton of fab work, just go through through your front brakes and drive it with the patience and care of a drum system.
Old 02-10-2013, 10:26 PM
brain75's Avatar
brain75
brain75 is offline
If you want to read it just for the academic challenge, here's the most detailed front end options (11 of em, none are novice level).
53-79 F-Series Steering & Suspension .: Articles
Now this guy went the bronco route (I'd have to re-read to see if it is the DANA 30 or the DANA 44):
https://www.ford-trucks.com/forums/7...d-f-1-4x4.html
Old 02-11-2013, 07:52 AM
bryanknie's Avatar
bryanknie
bryanknie is offline
If you have a Dana 44 just throw in some new gears and carrier if needed. I even made mine a posi. Randys is one of the vendors who have replacement gears.
Bryan
Old 02-11-2013, 11:19 AM
51FordTN's Avatar
51FordTN
51FordTN is offline
Bryan
Thank You for the info.
Old 02-11-2013, 09:38 PM
dmack91's Avatar
dmack91
dmack91 is offline
For general use, the stock front end works fine. I am in the process of going through mine right now.
I think someone said to plan on around $600 for complete rebuild. So far, my expenses are:
spring bushing set- $45
disc brake conversion - $280
king pin bushings - $40 (machine work supposed to be around $50)
Toyota Power steering box (not required) - $40+100 for pitman arm
Still need to get shocks and possibly rebuild the drag link. The disc kit is not absolutely necessary, but I decided to upgrade since I had to go through everything anyway. If you don't do discs, you will probably have around $100 into rebuilding the stock drum system.
Old 11-04-2013, 11:52 PM
gbuchalla's Avatar
gbuchalla
gbuchalla is offline
Are you interested in trading or selling your spare tire
Fender. I saw a 2012 in which you were interested in
swap or trade.
Old 11-05-2013, 08:48 AM
51PanelMan's Avatar
51PanelMan
swap or trade.
Which fender are you referring to? What year?
AgData
11-27-2016 11:51 AM
danfish
18
05-20-2009 07:00 PM
DenverGuys47
1947 and Older Ford Trucks
15
10-23-2006 09:33 PM
youdog99
12-14-2002 05:03 PM
maxwellthefatcat
11-06-2002 07:35 AM
Quick Reply: 51 Ford F1 truck (rear end/suspension swap)
