rear end swap
Old Feb 24, 2009 | 11:32 AM
danfish's Avatar
danfish
rear end swap
I'm going to be swapping the stock rear end in my '55 f-100 for a '57 9 inch also from a truck. Is this a pretty straight forward swap? Do the the leaf spring saddles lines up? And is the bolt pattern still 5 x 5.5 on the drums?
Old Feb 24, 2009 | 01:26 PM
Julies Cool F1's Avatar
Julies Cool F1
Hi Danfish,
I have a Bonus Built so this is a little out of my league, but there are tons of threads about this swap.
Just use the search function on the upper right corner of this forums main page. Type in " Rear End Replacent;" or, "9 in Rear End" etc, and all the posts will show up!
I remember doing that swap on my 55 about 25 years ago and it was a u-bolt undo/redo simple thing. But my old memory may be failing me.
Good luck
Old Feb 24, 2009 | 01:43 PM
low54's Avatar
low54
Yes F-100 1/2 ton trucks between '57 -72 will have the same wheel bolt patter as well as the leaf spring perch. good luck!
Old Feb 24, 2009 | 01:46 PM
55 f350's Avatar
55 f350
FTE Remembers
9 inchers have a 3 inch axle tube and the 44 uses a 2 or 21/2 so you are gonna have to get lucky { thanx stu!! } like me and land a set of shock mounts from an f250 of 48-72 vintage or buy some aftermarket ones like mid fifty has ...... julie your rear is the same width as the one all the rest of us have , take that as you will LOL!!!!!!!!!!!!!!!!!!!
Old Feb 24, 2009 | 02:11 PM
Mr Mayo's Avatar
Mr Mayo
Bring out the best!
There's a wealth of information in an article on this subject, right here on this site. Look at the header at the top of this page, and navigate the drop down menu under the "Articles/Specs" tab.
In part, the article says:
Ease of installation
Hands down, the easiest rear end to install into one of these trucks is the ‘57 – ‘72 F-100 rear end. If you're installing it in the stock (below the springs) location, it is a bolt in. The spring perches are in exactly the right spot. You need only use larger U-bolts as the older rear ends had a 2.5" diameter housing (in the area of the U-bolts) and the 9" is a 3" diameter.
The (possible) downside is that you get the 5 X 5 ½ " bolt pattern. Great if you're staying with the stock front end. Not so great if you're going with latter model IFS. Even your correct pinion angle is preserved with this alternative. It just doesn't get any easier than this.
Old Feb 24, 2009 | 02:17 PM
low54's Avatar
low54
you could go to any trailer store an get 3" U bolts...
Old Feb 24, 2009 | 02:18 PM
Old F1's Avatar
Old F1
I sure hope not!.......See what happens when you don't put your picture in!
Old Feb 24, 2009 | 02:19 PM
low54's Avatar
low54
LOL this is starting to go south
Old Feb 24, 2009 | 09:10 PM
55 f350's Avatar
55 f350
FTE Remembers
welcome to the dirty ol' persons club..................... LOL!!!!!! i believe to what i've seen and read on here that certain years explorers , and late model crown vics are a close match , but ya gotta weld spring perches on . i kinda loafed along and eventually was given the opportunity by a freind to trade an extra dana 44 for a 9 inch out of a 68 1/2 ton .
Old Feb 25, 2009 | 12:56 AM
Julies Cool F1
Dreamer!
Old Feb 25, 2009 | 08:18 AM
low54's Avatar
low54
If I really wanted to drop the rear a fella could mount the perches on the underside right???
Old Feb 25, 2009 | 08:58 AM
55 f350's Avatar
55 f350
FTE Remembers
uh huh . just go find a real parts house { we got a circle track shop and salvage yard here by the name of mullins } and buy a set of spring rerches and knock the old ones off and weld the new ones where you want 'em . remember to check your pinion angle and put it back the same . if i remember mine is up 4degrees ......
Old Feb 26, 2009 | 10:24 AM
hotrod351's Avatar
hotrod351
i got one out of a 1970 f100 1/2 ton, bolted right in.
Old Feb 26, 2009 | 10:33 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
The Explorer/Crown Vic wheels bolt pattern is different.
So what do you do then when your 5 lug 5.50" bolt pattern wheels won't work? Carry two spares?
The 1957/72 F100 9" rear ends are plentiful, far more durable then those integral rear ends, offer more axle ratios, and the bolt pattern is the same.
Old May 20, 2009 | 10:12 AM
dons 52's Avatar
dons 52
Help
I'm trying to put a 57 ford 9 inch rear end in a 1952 f-1, everthing I read says this will work, and I thought I had it made. It was all going perfect until I realized my drive shaft would be running an inch and a half from straight, pinion angle and everthing else is perfect. Help I'm confused.
Thanks
Don
