Low Oil Pressue
Feb 8, 2013 | 02:52 PM
Low Oil Pressue
Gentlemen,
As I was driving to work this morning, I got a warning of "Low Oil Pressure" and the guage (stock) had fallen to the "L". IIRC, if it was actually low the truck would not run correct? Is it a possible sensor? The truck still runs fine without issue.
Cheers,
Feb 8, 2013 | 03:06 PM
Certified Thread Hijacker
The oil pressure gauge is really an oil pressure switch that registers once it senses 7 psi. Basically to keep soccer moms happy.
And correct, the engine won't run without oil pressure, unlike a normal gas motor that would run until it seized without oil pressure.
To check the sensor, remove the connector and ground to the block, the gauge should peg full. If it does the switch is most likely bad.
Josh
Feb 8, 2013 | 03:14 PM
Quote:
Originally Posted by
Bullitt390
Josh
Thanks! Question: Where is the sensor??
Feb 8, 2013 | 03:31 PM
Single wire connector in the oil cooler cover, between the oil filter houseing and the turbo.
Feb 8, 2013 | 04:01 PM
here:
Jonathan Martin
Oct 8, 2024 07:17 AM
James6.7
6.7L Power Stroke Diesel
25
May 10, 2019 12:27 PM
f350ranchand
Dec 19, 2012 10:37 PM
Toyman
Nov 30, 2009 08:57 AM
Lee250
28
Nov 23, 2006 12:16 PM
