Rotor Hub Assembly
Old Feb 7, 2013 | 05:27 PM
spineshank02's Avatar
spineshank02
Rotor Hub Assembly
I just bought Rotors for my 1996 Ford F250 2wd and all they had where the Rotor hub assembly. I have no idea on how to install them. So does anyone knows how to install them and if I need any special tool? Any help would be greatly appreciated.
Old Feb 7, 2013 | 05:57 PM
Conanski's Avatar
Conanski
Yes you need a special bearing retainer nut socket that is often available for loan at larger parts chains. The basic process involves disassembling the locking hub assembly to gain access to the bearing retainer nuts, and with those removed the hub/rotor assembly will slide off the spindle. It would be worth it to at least get a blowup diagram of the front axle assembly to complete this task, and be aware there is a torque spec for the bearing retainer nuts.
Old Feb 7, 2013 | 06:14 PM
bashby's Avatar
bashby
He said 2WD, Paul. There's gotta be a million you tube videos. MAybe someone can link a good writeup, but it's pretty much the same as any older RWD car, no special tools needed.
Old Feb 7, 2013 | 08:25 PM
spineshank02
A link for a write up would be great. how long does it take? I got a write up off of here on how to change a shifter tube assembly. It was very easy to do
gilllawn
13
Jan 27, 2010 02:08 PM
jdubbtx
20
Sep 29, 2007 06:04 AM
gappy
Jun 25, 2007 07:36 PM
Sharkbait907
Oct 19, 2006 04:39 PM
The Tree
1978 - 1996 Big Bronco
May 12, 2004 09:29 PM
