help please 2000 ford ranger
Old Feb 6, 2013 | 08:43 PM
nas26car's Avatar
nas26car
i have a 2000 ford ranger manuel with the 3.0 V6 flex fuel engine to my knowledge E85 has never been used in it. here are my issues im having with it:
  • the gas guage is always past full no matter what
  • when i fill the tank up some gas leaks from it not much just a small puddle
the check engine light is on and has been since i bought it i ran the codes and these are what come up
  • P1451 EVAP Control System Canister Vent Solenoid Circuit Malfunction
  • P1408 EGR Flow out of Self-Test Range
  • P1000 OBD-II Monitor Testing Incomplete
  • P0401 Exhaust Gas Recirculation Flow Insufficient Detected
  • P0453 Evaporative Emission Control System Pressure Sensor High Input
  • P0460 Fuel Level Sensor Circuit Malfunction
Old Feb 6, 2013 | 10:10 PM
does home renovation's Avatar
It sounds to me like the previous owner tried to fix the broken fuel level sensor and botched the job.
Probably the fuel filler hose slipped off the tank when someone lowered it too far and that's why some of the gas spills. And the same thing happened to the evap hoses.
It's easier to take off the bed. Then you can see the top of the tank and make sure everything is connected properly.
Old Feb 6, 2013 | 11:14 PM
nas26car's Avatar
nas26car
will Seafoam fix some of my problems?
Old Feb 6, 2013 | 11:27 PM
85e150's Avatar
85e150
NO. You have a leak, something is loose, cracked, disconnected etc.
You must fix this before you end up on fire.
If you can't jump into it as suggested in the prior thread, take it to a shop and have the leak fixed along with your CEL issues. Your fuel and Evap codes will probably go away with the leak fix. Your EGR codes might be related because of an improperly attached or disconnected vacuum line somewhere.
Good luck.
Old Feb 10, 2013 | 04:14 PM
nas26car's Avatar
nas26car
All but one code is now fixed
Fixed all but one code P0453 generic evaporative emission system pressure sensor switch high input please help I don't know what this means I don't know what it is or looks like I'd like to fix this if anyone has pictures of it it would be greatly appreciated thanks in advance
Old Feb 14, 2013 | 11:43 PM
85e150's Avatar
85e150
Fuel tank pressure sensor, could be related:
NAPA AUTO PARTS
Related:
NAPA AUTO PARTS
"high input" might mean it's hooked up wrong, bad sensor, or something is allowing pressure to build in the tank because it's plugged.
Brahma
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
15
Jan 17, 2019 02:36 AM
rogerranger2122
Oct 3, 2016 09:09 AM
Manou
Apr 16, 2014 10:02 AM
rickm15752
Jul 4, 2013 02:32 PM
EPNCSU2006
Jun 2, 2003 08:55 AM
