Speedo Jumping
Old Feb 6, 2013 | 07:50 PM
C350CREW's Avatar
C350CREW
Speedo Jumping
Speedo started jumping out of nowhere Friday. Everything fine, made a stop and after restart, it started messing up.
Found a post about a similar problem where the member had to change the PSOM.
Do you guys think this could be it or should I pull the sensor and start there? My cruise is also not working? Can this be related?
The 3rd brake lite is working.
Old Feb 6, 2013 | 07:57 PM
Action4478's Avatar
Action4478
When mine was jumping it was a bad spot in the wiring from the frame to the VSS...
Old Feb 6, 2013 | 08:07 PM
Ken_C's Avatar
Ken_C
https://www.ford-trucks.com/forums/1...l#post12543853
Old Feb 6, 2013 | 08:24 PM
C350CREW's Avatar
C350CREW
I will start at the vss and check everything. Was cold, cold last week, lots of snow. Went thru some deep snow drifts, so I thought maybe a wiring issue or the snow may have pulled on a wire to loosen it.
Thanks
Any thoughts on the cruise?
Old Feb 6, 2013 | 09:44 PM
maverick1701's Avatar
maverick1701
Also might try cleaning the VSS...it gets covered in crud and makes things jump around.
Old Feb 26, 2013 | 09:42 AM
melgu's Avatar
melgu
Does anyone have an idea on where I could get a list of all of the abreviation used with diesel trucks and the meaning of abreviations - thanks
Old Feb 26, 2013 | 10:50 AM
mjunk1's Avatar
mjunk1
https://www.ford-trucks.com/forums/1...nsor-info.html
Old Feb 26, 2013 | 10:51 AM
maverick1701
there is a sticky thread around here somewhere with all that info..if I come across it I'll post it up.
Old Feb 26, 2013 | 10:55 AM
maverick1701
check here..
https://www.ford-trucks.com/forums/1...finitions.html
6brau
Dec 16, 2013 10:35 AM
KIRKWOOD IN LS
Modular V10 (6.8l)
Apr 23, 2008 11:49 AM
BigBluef250
Nov 1, 2007 04:07 PM
quest4air
Dec 10, 2003 08:09 AM
jjardine
Dec 15, 2002 09:24 AM
