C6????
Old Feb 6, 2013 | 03:53 PM
twisted84toyota's Avatar
twisted84toyota
Question C6????
I have access to a newer model C6 not sure of the year but it has a 208 on it!!
Will this have the same output shaft as my 79 C6 with the 205 on it???
Old Feb 6, 2013 | 07:39 PM
duallyhauler's Avatar
duallyhauler
To my knowledge yes all c6's had 32 spline output shafts but I would check novak-adapt to verify. The real issue you will have is the adapter housing length. The output shaft and adapter will have to be changed otherwise driveshaft's will not fit. Take a tape measure and look.
Old Feb 6, 2013 | 09:05 PM
twisted84toyota
My question is the length of the output shaft.......203 has the 5" and a 205 had the 8" I've never seen the 208 off the tranny to measure!!! This C6 is pretty built up and just what I need!! The guy wants to trade straight up for my SM435/205 setup.......
Old Feb 6, 2013 | 10:23 PM
duallyhauler
Ok so your first post said 208 now it's a 203? It really doesn't matter, which ever t-case you are using will need the adapter and outputshaft from the old one to make the driveshaft's work. The trans mount will be the same as well as the crosmember. So you will need to swap the output shaft and adapter from the old to the new.
Old Feb 7, 2013 | 08:47 AM
twisted84toyota
[QUOTE=duallyhauler;12809404]Ok so your first post said 208 now it's a 203? It really doesn't matter, which ever t-case you are using will need the adapter and outputshaft from the old one to make the driveshaft's work. The trans mount will be the same as well as the crosmember. So you will need to swap the output shaft and adapter from the old to the new
The C6 in question has a 208 on it I am asking if the output shaft the same length as the 205 C6 THERE IS A DIFFERENCE between the 203-205 output length....
Old Feb 7, 2013 | 09:41 PM
F-250 WARHORSE's Avatar
F-250 WARHORSE
Even if it is wrong and the tranny is right and what you want it isn't that hard to pull the valve body and the band and the gear train out to get to the snap ring to remove the out put shaft.
Old Feb 8, 2013 | 06:23 AM
twisted84toyota
That is great but not something I have time to mess.with!!!
I need a plug and play type.situation !!
redroad
Oct 24, 2012 05:10 PM
aunchman
Dec 7, 2004 01:58 PM
fastford456
Dec 26, 2002 11:17 PM
71swissaqua
Jul 14, 2002 12:22 PM
