C-6 T-case options
Old Dec 7, 2004 | 10:00 AM
aunchman's Avatar
aunchman
C-6 T-case options
I have a 1986 C-6 tranny attached to it is a New Process T-case. In the truck is a T-18 Tranny with a Borg Warner T-case. I want to use the C-6 in the truck but keep the Borg Warner T-case is there a tail shaft housing out there that will mount to the C-6 and accept the Borg Warner T-case? Or can you only use the NP T-case with the C-6 auto?
Thanks,
Chris
Old Dec 7, 2004 | 01:25 PM
andym's Avatar
andym
I'm pretty sure all ford tranny to transfer case bolt patterns and shaft sizes are the same, so it should swap right over.
Old Dec 7, 2004 | 01:58 PM
aunchman's Avatar
aunchman
Different tail shaft adn output shaft
I found out that the output shaft is different to I origanlly knew that the tail shaft is different. So in order todo this I beleive you need to change the output shaft and the tailshaft. Plus I heard that the New process is actually a half way decent T-case.
