Ac Blows Poorly
Old May 29, 2003 | 08:01 PM
sdanboise's Avatar
sdanboise
Ac Blows Poorly
My AC blows cold but the fan has no zip. My wife's new car will blow you out of the seat. Intake is clear. Is a new fan hard to put in? Where is it? thanks......
Old May 29, 2003 | 09:08 PM
Ultramagdan's Avatar
Ultramagdan
Question Ac Blows Poorly
Hello sdanboise and welcome to FTE!
Before we can offer advice on your fan we need to know what year of truck you have?
Old May 30, 2003 | 08:56 AM
sdanboise's Avatar
sdanboise
Ac Blows Poorly
Truck is a 99 F-150 supercab with 94,500. Truck has Vortec V1
and some other after market goodies. Truck runs great, the AC is cold, but the air never did blow real well. Wife's new care, sorry it's a Chevy, blows twice as good as mine ever did. Is there a better fan on the market? Could I take the old one in and have it rewired to perform better. The best truck in the world is no good in Phoenix if the air doesn't work well...............
Thanks, Scott
Old May 30, 2003 | 02:45 PM
mkirkham's Avatar
mkirkham
Ac Blows Poorly
Don't ask me why but Factory fans blow faster. If the motor has been replaced with a autoparts house fan, I would beat thats why!
Old Jun 1, 2003 | 12:04 AM
kinglg's Avatar
kinglg
Ac Blows Poorly
You might want to check the evaporator core for clogged
fins. I use my truck for work and I have to clean the coils about every other year. I remove the blower motor and spray
the coils with residential A/C coil coil cleaner. It works great. You might have to modify a pump up sprayer nozzle
for the job.
Old Jun 15, 2003 | 07:57 PM
rail's Avatar
rail
8th Gear
Lightbulb Ac Blows Poorly
Just had same problem, turns out the leads were wired wrong, orange goes to black and brown goes to orange, go figure, siemens, made in Mexico, seems like motor runs in reverse and a little air blows out vent when wired backward but not near what supposed to, after changing wires runs like a charm with full blower power.
'96 F-150 4X4
Old Jul 7, 2003 | 11:03 PM
smv219's Avatar
smv219
Cool Ac Blows Poorly
I just cleaned the one on my wife's Suburban and the A/C works much better.
Old Jul 12, 2003 | 04:32 PM
glnagrom's Avatar
glnagrom
Ac Blows Poorly
I just bought a 99 SD 7.3PS with the same problem--especially on max AC. Took it to two shops. Both said everything was fine, but I wasn't satisfied. Finally I decided to try to look into it myself. There was a Wal-mart sack sucked into the recirc air intake. To check for such a blockage, crawl under the dash on the passenger side and inspect it with a bright light. The air intake is right againts the outside wall of the truck. It is quite a way off the floor. High enough that you would never notice it vacuuming or detailing etc. Cured my problem. Wal Mart bags!
KrenzyRyan
Jul 8, 2011 03:12 PM
andypelle
2004 - 2008 F150
May 15, 2011 07:47 PM
texasjack
Jul 20, 2009 02:49 PM
philh
Aug 19, 2003 11:37 PM
davido
Jul 28, 2002 09:46 PM
