body part
Old Feb 5, 2013 | 09:45 AM
swmr1's Avatar
swmr1
body part
I have a 1983 f150.
What is the vent between the hood and the windshield called?
Where could i find a new one?
Old Feb 5, 2013 | 10:25 AM
1983F1503004x4's Avatar
1983F1503004x4
Originally Posted by swmr1
I have a 1983 f150.
That's called the cowl. It's what allows air to flow through to the fresh air vents down in the kick panels, and I believe directs air to the heater box. This way you can get air flowing through the cab if it's raining or some such without worrying about it getting in the cab.
You might be able to buy one as a replacement body panel, but I highly doubt it. Your best bet is a junkyard. Any cowl panel from 80 to 96 will fit, but 87 to 96 is an upgrade since the design of the cowl panel doesn't let leaves go through into the cowl, the heater, and the cab.
Old Feb 5, 2013 | 12:35 PM
81-F-150-Explorer's Avatar
81-F-150-Explorer
1987-1991 is the best match for an upgrade.
The 1992-1996 have two squirter nozzels, and the cowl does not match the contour of the 1980-1991 hoods correctly.
Without the cowl, your heater or A/C wouldn't function as this is where the air comes from to operate them. Also why leaves entering the cowl can cause heater fires.
Old Feb 5, 2013 | 01:25 PM
Fordzilla80's Avatar
Fordzilla80
Get one from a 1987-1991. You won't regret it. You'll regret getting an 80-86 one.
Old Feb 5, 2013 | 02:13 PM
mark1986F150's Avatar
mark1986F150
I can testify to the 80-86 cowl letting in A LOT of leaves. I filled up my shop vac (7.5 gallon capacity) TWICE with leaves from under the cowl and inside the fender well. Evidently no one had ever done cleaned that area out. Towards the bottom of the fender wells the leaves had turned into some of the finest compost you could ever want.
I didn't know that the later-model cowls would fit. I think I will be making this upgrade in the near future.
Old Feb 5, 2013 | 02:43 PM
f100beatertruck's Avatar
f100beatertruck
Yup... 87-91. The main difference is the 80-86 has open slots and the 87-91 is perforated with holes. It's a lot harder for leaves and crap to get in to it.
With that said if you're around Philly and you want an 80-86 one I have one in very good shape I'll give you...
Old Feb 5, 2013 | 03:31 PM
Archion's Avatar
Archion
Veteran: Marine Corps
Where in VA, I have one for 87-91 floating around
Old Feb 6, 2013 | 08:11 AM
Grubbworm's Avatar
Grubbworm
I have a 1983 f150.
Where are you located?
I have one off of my '85 that I will let go.
Old Feb 6, 2013 | 09:05 AM
ctubutis's Avatar
ctubutis
swmr1 - go HERE and finish filling out your Profile, would ya? What you enter in the Location field in the 3rd pane will be displayed in the top-right of each of your posts.
blackedout
Jun 26, 2012 02:07 PM
ford-lover1995
May 29, 2011 03:04 PM
cts1954
Jul 29, 2006 08:32 PM
Fordman65
Nov 28, 2003 06:45 PM
Thudpucker
13
Mar 26, 2002 10:04 AM
