Major engine swap
Old Feb 4, 2013 | 09:20 PM
austinlibke's Avatar
austinlibke
Major engine swap
I currently have a 1995 f250 with a 7.5. and have currently have grown to have a really big bone for a 7.3.. just curious as to exactly would have to be done to convert from my 7.5 to a 7.3
Old Feb 4, 2013 | 09:22 PM
85e150's Avatar
85e150
Engine, trans, fuel, cooling, exhaust, mounts, front suspension, controls, possibly gauges including speedo. Nothing to it.
A donor truck will be your friend.
Old Feb 5, 2013 | 08:37 PM
austinlibke
I thought the trans would work from a big block, just the top two bell housing bolts would not work. and even the front suspension??
Old Feb 5, 2013 | 09:28 PM
jas88's Avatar
jas88
Yes, just swap the springs.
Old Feb 5, 2013 | 09:31 PM
GNR22's Avatar
GNR22
You would be better off just selling your truck and buying a diesel. Unless you can get a truck with a 7.3 in it that's dirt cheap or something, like a couple hundred dollars.
Old Feb 5, 2013 | 09:38 PM
DIYiT's Avatar
DIYiT
I may be easier to think of what you want to do as a body swap than a motor swap. If you have a good body, find a rusted out diesel and use all your sheet metal.
Galaxie mike
Apr 11, 2016 09:24 PM
mick5731
May 6, 2011 11:45 PM
BLK SHP
General Diesel Discussion
Oct 22, 2010 01:07 PM
bronco69
Dec 19, 2007 07:58 AM
