P0470
Old Feb 4, 2013 | 11:06 AM
zhhouck's Avatar
zhhouck
P0470
My EGR and oil cooler went out and I replaced both along with the radiator. Since my check engine light went off twice and both times I replace the EBPS. It has just come on a third time. Would cleaning the EGR valve and Turbo help?
2005 F-350 Superduty 6.0
Old Feb 4, 2013 | 11:33 AM
Coronado's Avatar
Coronado
Well, typically speaking for the EBPS the tube that its connected to can also clog making the ECM set codes for EBP and EBP/MAP sensor correlation. I would try cleaning sensor and tube first, then start trouble shooting wiring and such.
Old Feb 4, 2013 | 08:28 PM
powerstroke72's Avatar
powerstroke72
Moved to the 6.0L Powerstroke Diesel forum.
Old Feb 4, 2013 | 10:32 PM
BLADE35's Avatar
BLADE35
P0470 EP Exhaust Pressure Sensor EP sensor, open signal return
Looks like possibilities are BAD EBP Sensor or Return Signal short
Old Feb 22, 2013 | 02:58 PM
zhhouck's Avatar
zhhouck
I bough a new EBP sensor and tested the one installed and the new one. The one installed put out .45 volts and the new one put out .75 volts. After putting in the new one, everything runs fine. Crazy thing, this is the third EBP sensor installed. Apparently the first two were faulty.
MOOKIEX4
Feb 7, 2019 03:50 PM
Fuzzpuss
Aug 2, 2016 09:04 PM
bcarless
Mar 5, 2016 08:25 PM
big dirty
Sep 22, 2011 09:43 AM
ejs05f350
Feb 2, 2011 03:19 PM
