getting 88 bronco running
Old Feb 3, 2013 | 09:52 PM
fordka's Avatar
fordka
just got this bronco a week ago. What should i do. It hasnt run in about 3 yrs. has 302. I got a new batterie in it put a little fresh gas and tried given some either. It will not start just turns over really good. Anything that i could try to get her goin. i been dumping gas down the intake thats the only way she will run andonly for about 15 or so seconds. i plan on changing out the fuel filter but i took the fuel line off and the gas draining back out looks pretty clear but does smell a little bad. i think the pump is kicking on but if i dont put any gas down the intake she wont do a thing but turn over. like i said if i put some gas in the intake she fire right up and run but thats all.
Old Feb 4, 2013 | 01:01 AM
Evan_P's Avatar
Evan_P
Honestly if its been sitting for 3 years, I would change ALL fluids and filters, change the plugs, cap and rotor. Possibly even wires. I would also highly recommend dropping the fuel tank and seeing how it looks inside. First though, check the fuel pressure at the rail. You will need a pressure tester. If it holds at 40 PSI after the pump primes, then the pump is good. If it is good, back-probe the injectors to see if they are firing. It sounds like a fuel delivery issue.
Old Feb 4, 2013 | 07:42 AM
fordka's Avatar
fordka
I tried getting a tester at napa yesterday. They didnt have any so my search continues. I really dont plan on changing anything till i know it runs. I dont wanna spend all that money and have it not being able to run. I do plan to do it but after i get her going.
Old Feb 4, 2013 | 09:15 AM
OldGrayMare's Avatar
OldGrayMare
Like Evan_P said, drop the tank and drain all that old gas out.
Old Feb 4, 2013 | 09:56 AM
Edgethis's Avatar
Edgethis
You don't neccesarily have to drop the tank. WHen you replace the fuel filter jsut unhook the line and then turn key on and let the pump drain the old gas out into a can. You should be able to see if theres anything in the gas, once its almost empty then fill the tank with fresh fuel. The full tank of new gas should neutralize the remaining bad gas in the tank for the most part.
Def check the pressure at the rail. A full tune up as Evan mentioned would be the first thing I'd do as well.
Old Feb 4, 2013 | 10:30 AM
fordka's Avatar
fordka
Well i will try to drain gas and i got a fule pressure guage yet hopefully sometime
Old Feb 4, 2013 | 08:38 PM
fordka's Avatar
fordka
Looks like im in luck. I found a pack of 8 brand new spark plugs that came in the cab of the 95 f150 i parted out.
Old Feb 4, 2013 | 08:42 PM
Edgethis's Avatar
Edgethis
Finding new parts is always a good thing!
Old Feb 4, 2013 | 08:46 PM
fordka's Avatar
fordka
Yes it deffinitaly is. That saves like $20 right there
Old Feb 4, 2013 | 09:00 PM
Diesel_Brad's Avatar
Diesel_Brad
Does the fuel pump even run?
Old Feb 4, 2013 | 09:01 PM
fordka's Avatar
fordka
I believe so. I took the line going to the filtr off and gas pumped out.
Old Feb 4, 2013 | 09:05 PM
Diesel_Brad
Do you have spark?
Old Feb 4, 2013 | 09:06 PM
fordka's Avatar
fordka
That i still gotta check. Wouldnt it tho if it was firing when i put gas down the intake
Old Feb 4, 2013 | 09:19 PM
Edgethis's Avatar
Edgethis
If it started when you poured gas into intake then yes you have spark.
Old Feb 4, 2013 | 09:30 PM
fordka's Avatar
fordka
Ok good i have spark at least
cklueee
1978 - 1996 Big Bronco
Oct 11, 2016 12:20 PM
paolca
2004 - 2008 F150
Jun 20, 2015 02:31 PM
osmith
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
Mar 20, 2009 06:00 PM
stooolieb
Sep 12, 2007 04:03 PM
BigNateK
Oct 12, 2003 09:00 PM
