converting carb to fuel injection
Old 02-03-2013, 02:10 PM
publiuss's Avatar
publiuss
publiuss is offline
I have an '84 standard shift that needs a carb rebuild. I also have a '94 automatic with a blown head gasket. Can I pull the fuel injection equipment off the '94 and put it on the '84. Before anybody suggests I just replace the head gasket, the body on the '94 is horrible and I like standard shift. Thank you.
Old 02-04-2013, 09:10 AM
AbandonedBronco's Avatar
AbandonedBronco
AbandonedBronco is offline
Yes you can. There are very few differences between and '84 and an '94 300. You'll most likely want to swap the head from the fuel injected engine over since the chambers are designed for the EFI computer.
The other thing to note is that you'll need the high PSI fuel pump from the EFI engine. Pull the mechanical fuel pump off the '84 and put a block-off plate over the opening.
There'll also probably be a few other issues to deal with as well.
The other thing to keep in mind is that the onboard computer for the '94 is for an automatic transmission. I think there are ways of "fooling" it for your manual trans, but it might just be easier to hit up a junk yard and get a computer out of an EFI truck with a manual transmission.
Old 02-04-2013, 03:01 PM
publiuss's Avatar
publiuss
publiuss is offline
So pretty much the thing to do is give up the manual shift and swap the engine and tranny over to the '84?
Old 02-04-2013, 03:18 PM
AbandonedBronco
Not at all, just get an ECU from a truck with a manual transmission. There should be dozens of them in a good junk yard.
Old 02-04-2013, 03:48 PM
davewild's Avatar
davewild
davewild is offline
ECU shouldn't be a big issue, only difference is in the clutch interlock/neutral safety switch wiring. You could probably run the manual truck on the auto computer.
The fuel system is the hardest part. If tanks interchange it will be easy.
Old 02-05-2013, 01:23 PM
publiuss's Avatar
publiuss
publiuss is offline
Saddle tanks on the '84, single on the '94. Can't I just put an electric pump on the '84?
Old 02-05-2013, 02:11 PM
AbandonedBronco
Yeah, an aftermarket electric fuel pump would be an alternative. Just be sure it's the proper PSI.
Old 02-07-2013, 09:20 AM
Andrew James's Avatar
Andrew James
Andrew James is offline
I did this swap about a month or so ago. You have the donor truck right? Super simple swap when you actually start doing it.
I did a 91 F150/EFI 300 w/M5OD into a 89Bronco/Carbed 300 W/originally AOD.
Easiest way is to just swap the whole complete motor. Pull the 84s and drop the trans. I found dropping the motor with trans attached to be the easiest. Pull 94s motor and trans out, drop straight into 84. I had the front clip off but pulling the radiator support should be sufficient. Hook up clutch pedal assembly and steal a fivespeed computer off a junkyard truck. Use all the wiring from the 94.
Either way, the head has to come up regardless of whether or not you swap whole motor or just the head with efi.
Old 02-07-2013, 09:27 AM
AbandonedBronco
For what it's worth, I pulled an engine out of my '81 and put another one in with only taking the radiator out. It's a tight fit, but you don't really have to remove a whole lot to lift the engine out of these big bays.
Old 02-07-2013, 08:25 PM
Andrew James
I did anyways but kinda had to cause my truck is lifted s fricken high.
Old 02-07-2013, 09:10 PM
AbandonedBronco
Ah, yeah, a lift would make a big difference when removing the engine! I wonder if in those cases, you could put the hoist in the bed of a small truck or something and drop it way down.
Old 02-09-2013, 02:05 PM
publiuss's Avatar
publiuss
publiuss is offline
I will be able to keep the current ignition system? Will my tank switch still work?
stroketildeath
07-30-2012 08:21 PM
Labhound
07-01-2012 02:38 PM
DHCowdude
03-25-2011 09:25 AM
privymaster
03-05-2005 06:36 AM
Belowh20
05-31-2004 05:28 PM
Quick Reply: converting carb to fuel injection
