V.advance setting?
Old Feb 3, 2013 | 01:50 PM
F-250 restorer's Avatar
F-250 restorer
V.advance setting?
I was checking my v.a. on my distributor. I noticed it begins to advance at about 900 rpm. Is that normal? I have an Isky 256 cam, with power band from 1500 rpm up.
Where would be the optimal setting for mpg and power?
Thx.
Old Feb 3, 2013 | 02:16 PM
devino246's Avatar
devino246
If it's running on ported vacuum, it should begin advancing just as you start opening the throttle plates. The mechanical advance should advance it further as RPM increases.
Old Feb 3, 2013 | 03:19 PM
montana_highboy's Avatar
montana_highboy
If you have an adjustable canister you can tune the vacuum advance for optimum performance, otherwise, a non-adjustable canister has a preset amount of advance built in, typically anywhere from 8-15 degrees.
The link below explains how to dial in the vacuum advance, if your motor is so equipped...
FORDMUSCLE webmagazine: Timing is Everything - Distributor Curving for Maximum Power
Old Feb 3, 2013 | 03:47 PM
F-250 restorer
Thanks for both replies. I'm still learning, and the forum is so valuable. Thx
F-250 restorer
Feb 4, 2013 12:49 PM
AbandonedBronco
25
May 3, 2012 08:44 PM
JSBaird24
Mar 16, 2003 03:11 PM
52 f1 younggin
Aug 10, 2001 05:19 AM
DannyP
Feb 12, 2000 08:23 PM
