where does the power come from that should be in the blue with red stripe wire?
That wire is power going into switch or is it power coming out of switch?
It's power going OUT. Dash light power leaves the headlight switch as the BLUE with RED stripe wire and goes to one side of the fuse. The other side of the fuse leaves the fuse panel as BLUE with RED stripe again and feeds the rest of the dash.
I put the dash back in and theres some dim lights , so some bulbs must be gone.
(I had the dimmer switch turned right over).
The left hand signal works but it doesnt flash on the dash?
Have tailights and front marker lights.
None of the sidemarkers or the dome lght works.
Guess ill start checking bulbs unless someone tells me all those things are on one circuit.
