E4OD water problems
Old Feb 2, 2013 | 12:24 PM
franklee86's Avatar
franklee86
E4OD water problems
okay i have a 94 IDI Turbo and everytime i go through a puddle or snow or its raining my trans will go into limp mode. and i have had many problems so i am actually quiet known of common problems see so far i have replace TPS and MLPS along with the tach sensor and speed sensor from previous problems so i dont think its any of those. and ive also had the trans wiring harness out and cleaned and taped back up. along with the plug that goes into the trans replaced. now i was wondering what do y'all think could be the problem? MLPS plug maybe??? help please and thanks guys
Old Feb 2, 2013 | 03:38 PM
Chevy_Eater's Avatar
Chevy_Eater
"E4OD" and "problems" are synonymous.
Try running a fresh ground from frame to transmission housing.
Old Feb 2, 2013 | 07:15 PM
'94IDITurbo7.3's Avatar
'94IDITurbo7.3
you have a bare wire somewhere underneath the truck that is exposed to the elements. time to crawl under the truck and start looking. could also be one of the connectors on the trans that is not sealing anymore and letting water hit the terminals.
Old Feb 2, 2013 | 07:37 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT
the MLPS connector was updated in '95 and all older plugs can now be updated to the newer style,to cure the very symptom your experiencing.very common tsb on this one.
do you know if this has been done yet?
neverenoughtools
Aug 16, 2018 09:56 AM
danlee
18
Oct 18, 2012 11:48 AM
jrb1027
Apr 27, 2011 04:04 PM
Fordranchero
May 17, 2010 08:36 PM
jboard
Aug 16, 2005 09:18 PM
