Replace fuel pump without dropping gas tank
Spoiler alert (major moron moment)
So my brother drove two hours from out of town to help me figure out how to solve the locking ring problem. The problem was that the ring would tighten up like it's threading properly, then when I would put turning force on the ring, it would pop off. When I described how the parts look, I told him it was like screwing on a lid to an industrial-size mayonnaise jar.
My brother tried it and noticed that before the ring pops off, one side of the ring rides up. It took him less than two minutes to figure out that if you put downward pressure on the top side of the ring that rides up, the ring will jump down the fuel tank threads, whereupon you can check if the ring is aligned properly and continue securing the sender assembly. So he wedged a breaker bar with a padded tip (to keep it from scratching anything) between the truck bed and the locking ring and pressed down. It dropped in like it was supposed to, without much persuasion. I should note that there is the possibility of breakage if the locking ring isn't in good condition, but since this locking ring looked fairly new, there was reason to try this procedure. I was happy this worked, but very upset with myself for not thinking of it first.
We finished re-assembling with the parts that we had just to get the truck running again, but there are a few hoses and a tank seal that need to be replaced. The scary thing is now I can't even hear the fuel pump running, but I do know it starts and I can go where I need to go again.
Did my 02 Expo 4x4 fuel pump to the T per directions in post.... worked exllenct my fuel pump died half block from house and i filled it the night before and even squeezed an extra dollar in the tank.... total job time was about an hour this included a trip to the store store for a strainer and pump only change out!!!
thank you very much for posting..... i stumbled on this this morning just before i was going to drop tank after looking for quite a while yestderay.....
-vic
