Hmm, well maybe the PDF just shows the whole box out because it was easier for them to take the pictures that way... Bill's account would seem to indicate as much.
It is not a trivial task to remove the whole plenum from the truck! I'm thinking you pretty much have to pull the whole dash. At that point it's almost easier to buy a new truck than replace the heater core.
Yes, remove the dash, but it could be sooooooo much worse.
Originally Posted by 85lebaront2
You should try doing anything to the HVAC on an Explorer or worse yet a Pacifica.
Or a Taurus SHO
Once you've gotten to that point, it's still at least another 3 hours work to get to this point:
Removing the heater core is actually pretty easy - a few 8mm screws hold on the cover and it comes right out:
But, to get the evaporator out, the official Ford docs have you using a hot knife and/or saw to cut open the plastic case so it can be extracted:
Reassembly is actually somewhat faster, about half the time:
Except if you're gonna replace that dang Liquid Line... the aftermarket one wouldn't fit between the exhaust manifold and firewall:
Sorry for the hijack - now, back to your regularly-scheduled rambling
Actually Chris, I think it's not just the SHO, I would bet mine is just as bad, as for clearance, I have the 90° 3.8L V6. The back side on that one is interesting.
9wire, you must have doubled the Chevette's value. I figured Chevy was working on disposable cars. First came the Corvair (although I kind of liked them), then the Vega where they got it close, and finally perfected it with the Shovit (Chevette).
There were glimmers of hope in there though, with the Corsa and Cosworth for the 'Vair and Vega, respectively. But, by the time of the Shovit all glimmers had died.
Matt's Corsa 140 was a blast to drive. It had what Chevrolet called "heavy duty" suspension (read handling package) and somewhere between a stage II and stage III Yenko engine. I played with the carb jetting and it got pretty decent fuel economy, but would still go. Biggest complaints on it were the headers and glass packs would drone horribly at around 48 mph and due to the headers the heat left a bit to be desired.
For the latter, I built a set of lower ducts that fit around the headers and took stock thermostats. It helped, but you still had issues with the automatic chokes and so so heat (kind of like a beetle).
Had a fraternity brother, a rich kid that was studying mechanical engineering but didn't have a clue, who had a new Corsa. Came in one day and said "I was going down the highway at 60 and decided to check out the fully synchro'd transmission by putting it in first gear. Something went bang and it quit pulling." I did a quick mental calc and told him he'd just blown the clutch by rev'ing it to 7 grand. Sure enough, when Chevrolet called him they said the clutch was blown and wouldn't be covered by warranty. Duh!
As for heat in a Beatle, have you ever drive a Transporter, the van or bus? They have the same engine, but instead of dumping the "hot" air into the cab just ahead of the engine they run it up a 3" stove pipe to the very front where it comes into the cab in the very, very front of the vehicle. By then whatever air was "hot" isn't, and you are faced with the choice of sending it fully to the defroster or fully onto the floor 'cause partially does no good for either function.
