Sponsored by: Real Truck
4x4 Problems!
Old Jan 30, 2013 | 05:18 PM
CoalRollerUSN's Avatar
CoalRollerUSN
4x4 Problems!
I am the owner of a '01 f250 7.3 powerstroke. Just recently the 4x4 will not work. The lights turn on the dash when i click it in and the transfer case engages, but the 4x4 will not work, neither front tires will spin in snow and if i lock the hubs in and drive it makes a realll ugly noise going down the road.. Any suggestions? and also I was wondering about buying a stage 2 ats transmission and comments about that?
Old Jan 30, 2013 | 05:26 PM
jacsent's Avatar
jacsent
If you Get a racket when 'locked' i'd Hazard a guess at a bad hub. Failing that it doesn't get much better.... Likely blown spider gears in front dif.
Someone with more experience may have a better idea.
Good luck
Old Jan 30, 2013 | 05:36 PM
Firekite's Avatar
Firekite
If you manually lock just one of the hubs, do you get the same noise? What if you only manually lock the other hub?
Old Jan 30, 2013 | 05:39 PM
CoalRollerUSN
Actually, the noise only happens when the drivers side is locked in, if its not theres no noise
Old Jan 30, 2013 | 05:46 PM
JamesB128's Avatar
JamesB128
Pull the Drivers side hub. Be prepared to pick up the pieces.
Old Jan 30, 2013 | 05:52 PM
CoalRollerUSN
if it was only the drivers side, wouldnt the passengers side tire spin??
Old Jan 30, 2013 | 06:21 PM
Tom's Avatar
Tom
Nope, remember that your front axle has the same type of hypoid differential that your rear axle does. Meaning that torque is equalized between the shafts, and with one shaft not being connected to the wheel the torque is going to be very small.
You will have no power to the front wheels unless both hubs are working and locked.
Old Jan 30, 2013 | 06:25 PM
CoalRollerUSN
alright good deal. anything about the ats transmission?
Old Jan 31, 2013 | 09:26 AM
Firekite's Avatar
Firekite
That's close, but it means what's actually happening is that all the torque is being transmitted to the shaft that has the least amount of resistance (which is why they invented limited slip and lockers). Either way, the end result is the same, as stated: "You will have no power to the front wheels unless both hubs are working and locked."
joeinmn
Jan 20, 2018 12:41 PM
ampslw
Jan 21, 2011 11:02 PM
af11
Offroad & 4x4
Jan 15, 2011 05:20 AM
johniebomb
Oct 13, 2008 03:32 PM
medicone67
Feb 15, 2003 08:54 PM
