2012 4x4 grinding then bang - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 01-17-2018, 10:08 AM
joeinmn joeinmn is offline
joeinmn is starting off with a positive reputation.
lately, I've been getting a grinding noise followed by a banging in the drivetrain of my truck. it doesn't seem to happen when i first leave the driveway, but if I make a stop, shutting down the truck for 10 minutes or so, when I go to leave again, it will start to make a grinding, sometimes sounds like a ratcheting noise, then it bangs, then all seems ok.
the truck has almost 100k miles on it. I'm wondering if it has something to do with the vacuum lock outs, but I hate to start throwing parts at it.
has anyone experienced this issue?
Old 01-17-2018, 10:19 AM
sxrfun sxrfun is offline
sxrfun is gaining momentum as a positive member of FTE.sxrfun is gaining momentum as a positive member of FTE.
Are you in 4x4 or 2x4 when this happens? What position are the hubs in...auto or lock?
Old 01-17-2018, 10:52 AM
Quote:
thanks for the reply. I am on 2wd when it happens, the hubs are in auto.
more info on the truck. it seems to shift into and out of 4wd find when called upon.
Old 01-19-2018, 10:01 AM
StewB's Avatar
StewB StewB is offline
StewB is starting off with a positive reputation.
I had similar sounds right before a locking hub exploded. Needle bearings in the hub were dry and came apart and jammed up.
Old 01-19-2018, 10:29 AM
Bugize Bugize is offline
Bugize is starting off with a positive reputation.
I had this happen a couple weeks ago,after going through a car wash. I blamed it on that,and cold weather....I figued if i went through the jet dry,plus parked where the sun would hit it, that would help with any freeze up...We have had warmer weather lately,and it hasnt acted up since.
Old 01-19-2018, 11:20 AM
RailDawg RailDawg is offline
RailDawg is starting off with a positive reputation.
If you haven’t serviced the auto hubs I would suggest doing so even it’s not related to the noise.
I finally found the correct o-rings on RockAuto.com and plan to service mine this week.
Old 01-20-2018, 12:46 PM
Quote:
Originally Posted by RailDawg View Post
If you havenít serviced the auto hubs I would suggest doing so even itís not related to the noise.
thanks for the replies, it doesn' seem to happen in the warmer weather...
when you say service the hubs, what does that entail? I found the kit on rock auto with the gasket and a couple orings.
Old 01-20-2018, 01:41 PM
Superdave71 Superdave71 is online now
Superdave71 is starting off with a positive reputation.
The vacuum is applied to disengage the hubs. When the vehicle is shut down, I believe the hubs are likely to engage, but upon startup, vacuum is applied and they disengage. The ratchet sound is hesitation in this action. I guess you have a minor vacuum leak, either from a hub seal or line..
Let's share some horror stories Encho 1978 - 1996 Big Bronco 17 02-08-2018 03:14 PM
Transmission dying help needed Corbin probasco 1987 - 1996 F150 & Larger F-Series Trucks 0 09-18-2017 10:35 PM
Loud banging while cranking microbc 6.0L Power Stroke Diesel 9 01-10-2017 02:28 PM
Banging when going over bumps dlit 1999 to 2016 Super Duty 9 08-25-2016 12:08 AM
Well, it wasn't the torque converter brichert General Diesel Discussion 5 06-29-2016 04:11 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
