Overheating problems
Old May 29, 2003 | 09:17 AM
mcguyver's Avatar
mcguyver
I have a built 400 in my 78 F-150 and I am having overheating problems. My truck came from the factory with a 3 row radiator and a 195* thermostat. There are no leaks and the system is maintaining pressure but it is still overheating. What would be the best way to cure this problem.
A 180* thermostat?
A 160* thermostat?
A new edelbrock alum water pump to replace the origanal stock one?
A used 4 row 460 radiator?
A new Be-Cool custom fit alum radiator?
A oil cooler?
A flex fan to replace the origanal stock fan?
I would like to fix this problem for good however I would like the solution to be as cheep as posible. Any sugestions. Thanks.
-Jim
Old May 29, 2003 | 11:52 AM
mudcobra's Avatar
mudcobra
I would definately pitch the 195 thermostat. Try a 180. What kind of shape is your radiator in? Maybe it just needs to be rodded out? I've had radiators cleaned out at the radiator shop before and then be stopped up again within a year, all due to the high mineral content of the water in my area. I now use distilled water and antifreeze.
Old May 29, 2003 | 11:57 AM
mcguyver's Avatar
mcguyver
I dont think my radiator is cloged, got it repaired and cleaned end of last summer and we usally dont have cloging problems in these parts anyway. In regards to the thermostat where could I get a 180*, I know they exist but the parts stores only have 195* for these motors, they have a differnt thermostat than all the other ford engines. You know where I could pick one up. Thanks.
-Jim
Old May 29, 2003 | 12:04 PM
mudcobra's Avatar
mudcobra
I had a 180 in my 400 that I just tore down and have used a 160 in a Cleveland before, however i don't know if the 160 is still available. I just went to the parts store and told them I wanted a 180 theromostat for a 400 engine. They might give you some BS about that is not what came in it factory just say I know and insist on a 180, even ask about a 160 and see what happens, even try differant parts store to see what happens.
Old May 29, 2003 | 01:29 PM
beartracks's Avatar
beartracks
180 thermo from Summit racing/Moroso. It's a RobertShaw hipo.
RV/heavy duty clutch fan.
4 row radiator. Three is to little.
This set up cured all my problems
I'm using the BeCool now but it would lead to a lot of other projects. Search for my post on should exhibit.
Old May 29, 2003 | 01:45 PM
macguyver's Avatar
macguyver
If it's going to overheat, a lower temp thermostat just delays the inevitable. Once the coolant temp reaches 200°, it doesn't matter if the thermostat opened at 180° or 195°. It's still open. RobertShaw thermostat is recommended.
A flex fan will usually pull less air than a factory fan with the fan clutch. Make sure the fan shroud is in good shape. No more than 50/50 mix on the antifreeze. More antifreeze will boil at a higher temp but won't cool as well.
Is it overheating going down the road or mainly at idle in traffic?
If everything else is in good shape, a 4 row radiator might be your best option.
Just my 2¢
Greg
Old May 29, 2003 | 04:42 PM
cartwright's Avatar
cartwright
After rebuilding my 400 it kept overheating. I changed thermostats 3 times and it still kept overheating. I ran it for about 3 months with no thermostat, then put in a 160 and havent had a problem since. Sometimes a new or high flow water pump will push the t-stat closed. Also, is your motor overbored? If a 400 is bored past 40 over, it will almost always overheat.
Old May 29, 2003 | 11:19 PM
Torque1st's Avatar
Torque1st
Posting Legend
Listen to your "Uncle" MacGuyver and Beartracks
Old May 31, 2003 | 12:00 PM
mcguyver's Avatar
mcguyver
found the problem, It was electrical. To be positive I even got an aftermarket temp guage and all was fine. Thanks everyone.
-Jim
P.S. I would still like to get a 4 row becouse I am pushing it with the three row in the summer. What is the most I should pay for a used 460 4 row radiator to fit in my truck.
monstrs
Feb 28, 2015 11:59 PM
Kregj
Jun 6, 2014 05:37 AM
jdcpjc
Jul 7, 2012 03:32 PM
CXA152
33
Apr 25, 2012 11:08 PM
85fordf150blue
Aug 2, 2011 06:30 PM
