Truck Overheating
Old Aug 2, 2011 | 12:53 PM
85fordf150blue's Avatar
85fordf150blue
Truck Overheating
Ok so I have completed the rebuild of the 302 in my 85 f150. I needed to run the engine for 20 minutes to break in the new cam. after about 8 minutes I noticed the temperature rising quickly. So I turned the truck off and the temperature continued to rise. I need help figuring out why it is over heating. The fan was spinning fine the belt was not slipping. The thermostat was brand new and I tested it in hot water before installing it. The water pump is brand new The radiator was flushed out. I will probably go to a 2 row radiator, but I'm not so sure that the radiator is my problem at this point. A
Any ideas what this could be and how to test for them?
Old Aug 2, 2011 | 12:57 PM
ctubutis's Avatar
ctubutis
First thing to come to mind is a wrong water pump - one intended for a Serpentine belt which spins in the opposite direction.
I think what I would do is let it cool off some, remove the radiator cap, start it up and see if you can see fluid circulating through the radiator.
Another possibility is a wrong fan - also one intended for a Serpentine system where the blades are angled to accommodate the "backwards" rotation.
Old Aug 2, 2011 | 01:30 PM
85fordf150blue
I had the radiator open and I was actually seeing a lot of splashing of the fluid out of the radiator. I'm wondering if the thermostat is not working. so its not flowing.
Old Aug 2, 2011 | 02:19 PM
Franklin2's Avatar
Franklin2
I am almost 100% sure you have air trapped in the engine block. Pull a sensor off the top of the engine that goes into the water jacket, and make sure coolant comes out. Then run it, and let it burp the remaining air out of it.
Old Aug 2, 2011 | 02:29 PM
85fordf150blue
I just took the thermostat out and it does not have weep holes of any sort. I'm going to put a new thermostat in it and do what you said to get the air out. Then tonight I'll see how the temp is and hopefully get this cam broke in.
Old Aug 2, 2011 | 06:30 PM
85fordf150blue
That was it. It's running now. However, it is really running hot out the exhaust. I'll post a new topic.
Gene Allen
Dec 16, 2013 06:15 AM
KevinBales
Sep 11, 2007 03:08 PM
gwm
Aerostar
Apr 23, 2006 09:35 AM
TigerDan
17
Jul 24, 2004 11:28 AM
Racerdave
18
Sep 11, 2003 06:28 PM
