99 Explorer vibration slight rough idle
Old May 29, 2003 | 09:03 AM
mendes9's Avatar
mendes9
I have a 99 explorer XLT with 42K miles, that has an intermittent vibration. It sounds as though it's right under the driver/passenger, perhaps it's the exhaust but unsure. There is also a slight rough idle as well, it might go up or down a few hundred RPM nothing dramatic. I read on goggle that this was a common problem and the issue is with the high pressure power steering hose, and that ford came out with a larger diameter hose that fixes this idle/vibration problem. I was wondering if anyone else here might have seen this issue and can give me some suggestions.
Old May 29, 2003 | 12:08 PM
stubborn1's Avatar
stubborn1
The vibration may be caused my a loose heat shield on the cat. converter. Haven't had it on my exp yet, but a friend had it happen on a 96 exp. The vibration would occur during acceleration between about 1500-2500 rpm.
ramirez7589
Jul 19, 2015 03:59 PM
TestPoint
Mar 9, 2015 07:00 AM
66shadow
Jan 21, 2015 12:12 PM
Speed-demon
3.8 & 4.2L V6
Apr 17, 2014 09:01 AM
jimberg
Sep 20, 2005 02:17 PM
