transmission issue??
Old Jul 19, 2015 | 12:40 AM
ramirez7589's Avatar
ramirez7589
This morning i noticed when i started the truck had a rough idle shaking truck. The truck felt weak. Boost would go up but truck felt like it was in sand. While coasting on the highway at 50-55mph the truck not only lags in power but vibrates viciously untill the overdrive kicks in that vibrations in cab and ssteering wheel go away.. any ideas on what might be going on
Old Jul 19, 2015 | 05:44 AM
mustang_309's Avatar
mustang_309
Scan it for codes, you can have pending codes without a check engine light. You probably have a bad injector.
Old Jul 19, 2015 | 07:47 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
All of your symptoms point to an engine problem. I'm surprised you think it is the transmission.
Old Jul 19, 2015 | 02:08 PM
ramirez7589
Well at the time i wrote the post i did. I went to a local O'Reilly parts shop and they could.not ise the diagnosis tool onny truck tey said because there was no check engine light. The engine shakes rough and gets worse on moderate acceleration. from a dig it doesnt even pick up the same. Ive been doing a little more research and now its leading me to think its the FICM or and injector. there has been black smoke on cold start up the last couple of months.
Old Jul 19, 2015 | 02:20 PM
mhoefer's Avatar
mhoefer
Invest in scangauge or DashBoss rpso you up an narrow this down. It will help a lot to be pointed in the right direction from the start.
Old Jul 19, 2015 | 03:52 PM
Mark Kovalsky
That's because they don't know what they are doing. If you went to a repair shop instead of a parts store they would be able to read the codes whether or not the light is on.
Old Jul 19, 2015 | 03:59 PM
69cj's Avatar
69cj
Just because there's no cel doesn't mean there's no code. Most of the people at the parts stores have a limited amt. of vehicle knowledge and it's related to the parts they sell. I'm not putting them down, it's just a fact of life. They're not paying these people ASE wages.
BigRed7.3l
Jan 14, 2014 03:57 PM
BigwillyG
Dec 30, 2011 05:12 PM
IHMANKY
Aug 13, 2011 09:42 PM
fireeater91
Aug 1, 2007 05:21 PM
Sean Kennedy
2004 - 2008 F150
15
Nov 27, 2004 12:57 AM
