Probably should go in Super Duty forum, but this is the one I usually come to if I come to FTE.
Three of my four Aluminum wheel valve stems are seeping at the wheel seal. My local tire man did not have proper seals to replace these. Quick Lane wanted $20.00/per stem plus labor. "I said, No, thank you!"
I've found a resonable source for a complete stem, but does anyone know where to find just the the rubber seal. That's really all I need.
tire stems are you talking something like this? i would assume you would have to get the whole stem if so. do you have the dullie extionsons on the stems? i think labor would be like ~$15-$20 each where i work plus the stem, that's with taking tire off vehicle.
