f250 1982 wireing problems need help
Old Jan 29, 2013 | 02:53 PM
gorms14992000's Avatar
gorms14992000
looking fore wiring diagrams from altanator to battery
Old Jan 29, 2013 | 03:05 PM
Franklin2's Avatar
Franklin2
This is the one if you have factory gauges in the cluster.
Old Jan 29, 2013 | 04:18 PM
gorms14992000
82 ford f-250XL 351 (modified)
wireing harness from altanator to regulator and batter any one kno how to wire it? need help
Old Jan 29, 2013 | 07:29 PM
ctubutis's Avatar
ctubutis
Franklin posted the exact wiring you're talking about if your dash has gauges and not idiot lights, do you maybe need something else? Or something more? Or, what?
Old Jan 31, 2013 | 02:15 PM
gorms14992000
i have guages on the dash of the truck but i restored my truck and all the wires were so bad and broke off cant remember where they went
Old Jan 31, 2013 | 02:16 PM
gorms14992000
thanks dave but i dont have a diesel i have a 351 modified
Old Jan 31, 2013 | 05:55 PM
Franklin2's Avatar
Franklin2
That's not a diesel diagram, that's a diagram for all trucks with the external alternator and gauges in the dash.
Here is the diagram if you have idiot lights in the dash(which you said you had).
Do you have any wires out under the hood to work with?
Old Feb 1, 2013 | 03:05 PM
gorms14992000
i have all the wires diconnected there cut & burt have to replace them all there was a cluster of wires that came out next to my blower motor that had a plug on in but pretty bad melted have to make a new one cant find one anywhere went to bout 60 junkyards there all gone thanks fore the diagram
Old Feb 1, 2013 | 03:11 PM
gorms14992000
my altanator has a plastic plug on the side of it with two post on each side of it so there should be 2 wires fore the plug and one wire fore each stud right four wires all together diagram only shows three??
Old Feb 1, 2013 | 07:49 PM
Franklin2's Avatar
Franklin2
The alternator you should have should look like this:
If you look close at the casting of the alternator, the terminals are stamped to mark them.
Does your alternator look like this? If so, I think it's a later model and the wrong one for your truck, but possibly you have had a motor swap at one time or another.
BigB9000
Dec 29, 2012 02:37 PM
1930 Dodge
18
Dec 10, 2012 12:19 PM
mudder460
Oct 25, 2010 06:14 PM
76fordfan
Apr 29, 2007 05:45 PM
rottenchevy
Electrical Systems/Wiring
Nov 3, 2003 08:43 PM
