Fuel/electrical
Old Jan 29, 2013 | 08:06 AM
86ford150guy's Avatar
86ford150guy
Fuel/electrical
Hello,
I have an 86 EFI ford Truck. The other day i came from work and next morning was going to start the truck and all it would do is turn over then the battery went dead. Then another battery went dead. I found the starter was shorted to ground. Since then i have replaced. the starter, the EEC relay, the high pressure pump, the fuel pump relay, the TFI, the rotor. I checked the fuel rail and found no gas coming in, i have spark and the pump is putting out fuel.
Any advice would be appreciated. Thanks
Old Jan 29, 2013 | 10:34 AM
ctubutis's Avatar
ctubutis
I'm confused as to what your problem is. Did you replace all that stuff in an attempt to fix your problem? Or, did the problem come after replacing all or some of those parts?
Kinda sounds like you're talking about more than one problem... battery goes dead, fuel not at the fuel rail but apparently it's pumping fuel.....?
Old Jan 29, 2013 | 05:17 PM
86ford150guy
Yes i replaced everything after the problem came up.
Old Jan 29, 2013 | 07:57 PM
ctubutis's Avatar
ctubutis
OK, cool. I'm sorry, but I'm still confused what the problem is....
Is the battery still going dead?
Are you saying you don't have fuel at the fuel rail? (If so, what method did you use to test for it?)
Old Jan 29, 2013 | 08:07 PM
86ford150guy
I took the test plug out to check for fuel at the rail, i changed the TPI out the battery then it seemed (the battery) to hold a charge. I can hear the fuel pump kick it then it shuts off. Also i took the fuel line off on the front of the filter and fuel gushed out i did the by pass at the DPI and got the pumps to run,,,,,still no fuel?
Old Jan 29, 2013 | 08:23 PM
ctubutis's Avatar
ctubutis
1986 EFI, presumably F150. Is this one of those with two fuel pumps? A low-pressure in-tank pump, and a high-pressure pump closer to the engine?
What is your fuel pressure at the rail?
Old Jan 29, 2013 | 08:29 PM
ctubutis's Avatar
ctubutis
I' confused... what is a TPI? And how does it relate to the battery?
...i did the by pass at the DPI and got the pumps to run,,,,,still no fuel?
What is a DPI?
Not trying to be a jerk, I'm just not sure what you're trying to say. I'd venture to say most people feel the same way, looking at the responses this thread has gotten.
Old Jan 30, 2013 | 07:30 AM
86ford150guy
Its the direct plug in to by pass the fuel system for testing otherwise known as a FP diagnostic lead. TPI is referred to in the Haynes book, its the distributor module. The pressure is O at the rail.i have sent it to the Ford Dealer, evidently there was a recall on this fuel system the truck has only 116k on it must have been missed.Thanks for your help.
cstrack
1997 - 2003 F150
35
Jun 6, 2014 11:45 AM
Aveech
Mar 31, 2014 06:45 AM
dktool
Dec 22, 2012 12:00 PM
polarisman729
Feb 22, 2008 07:16 AM
hagg26
Sep 16, 2005 05:25 AM
