Cam questions
Old Jan 30, 2013 | 08:56 PM
JJray's Avatar
JJray
Ok cool ill look into all this stuff. Is it a bad choice for 3 angle valve seat grind?
Old Jan 30, 2013 | 09:00 PM
Gary Lewis's Avatar
Gary Lewis
3-angle is good.
Old Jan 30, 2013 | 09:05 PM
JJray's Avatar
JJray
Alright. Whats this emissions thing you guys are talking about grinding out?
Old Jan 30, 2013 | 09:25 PM
85lebaront2's Avatar
85lebaront2
Old School Hot Rodder
Right here in the exhaust ports.
Old Jan 30, 2013 | 09:34 PM
Gary Lewis's Avatar
Gary Lewis
And, from a different angle, the hole Bill circled is the end of the channel that the upper red line runs through. The hole in his picture is the bottom end of that drilled passage.
Old Jan 30, 2013 | 09:37 PM
Gary Lewis's Avatar
Gary Lewis
And here's Bill's view with the bump ground out:
Old Jan 30, 2013 | 10:13 PM
JJray's Avatar
JJray
Is there any special tools or tricks to grinding that out? Does ever exhaust port have that?
Old Jan 30, 2013 | 10:25 PM
Gary Lewis's Avatar
Gary Lewis
The trick is to not go too far as there is a water passage behind it. But there is a LOT of metal there so it isn't likely you will strike water. As said, use a die grinder and a carbide burr. And, oddly enough, most of the heads I've checked had the bump in three of four ports. The one without the bump is the crossover port where exhaust goes through the intake for heating.
But, if you start with a better head there won't be as much of a bump.
Old Jan 30, 2013 | 10:29 PM
JJray's Avatar
JJray
Is there anyway to plug the passage that heats the intake? Or is that a needed passage?
Old Jan 31, 2013 | 07:41 AM
Gary Lewis's Avatar
Gary Lewis
There are gasket sets that plug that passage. But, I wouldn't do it as it really is beneficial in cooler weather.
Old Jan 31, 2013 | 04:27 PM
JJray's Avatar
JJray
Got ya. Is there any machine work to help the intake?
Old Jan 31, 2013 | 04:40 PM
Gary Lewis's Avatar
Gary Lewis
Port matching is all, and there are some that say you actually want the intake's ports to be smaller than those in the head to prevent reversion, meaning backflow.
Old Feb 1, 2013 | 01:01 AM
  #28
JJray's Avatar
JJray
Whats the debate on that one?
Old Feb 1, 2013 | 07:28 AM
  #29
Gary Lewis's Avatar
Gary Lewis
Some say you should match the ports perfectly and others say the intake port should be slightly smaller than the head.
Dustin Simmons
25
Jan 22, 2018 10:50 AM
Boss50
Mar 17, 2013 09:51 PM
bigblueovalman
Dec 31, 2007 02:18 PM
fordfan28
May 20, 2007 09:31 PM
bluepartsman
Mar 18, 2005 10:34 PM
