Replacing rubber fuel lines
Old Jan 28, 2013 | 09:24 PM
devin28's Avatar
devin28
Hello. I have a 1977 ford f150. 2wd. 400. My weekend project this time i'm going to try and replace the rubber fuel lines from rear to front. Anybody have an idea of how many rubber lines there are? Also what size would they be? From reading different threads on here i've gathered there is one on the rear tank which I should be able to loosen the two straps and have enough room to get to the line. The tank on the side i'm assuming is the same way. There are 3 on the fuel selector valve? the little box on the drivers side frame rail. 1 from the fuel pump to the frame that connects into a metal line. so 6 all together maybe 7? should I just buy a roll at the parts store? and again what size should i get? thanks in advance for the advice.
Old Jan 28, 2013 | 09:33 PM
rockittsled's Avatar
rockittsled
also be aware that there is a spec for alcohol resistant hose, Jsomething or other
Old Jan 28, 2013 | 09:41 PM
fmc400's Avatar
fmc400
MSEE
Just get some bulk fuel hose from the parts store and cut to fit. You'll want to ask for fuel hose by name. Everything between the fuel pump and tanks should be 3/8", everything between the fuel pump and carburetor should be 5/16".
Old Jan 28, 2013 | 10:42 PM
Blue and White's Avatar
Blue and White
Agree. A few (3-4') of 3/8 and one foot of 5/16" should be more than enough. Also may need some new clamps.
hail destroyer
24
Jun 8, 2018 10:27 AM
Niveyinc
Sep 4, 2017 06:46 AM
Vegas123
May 25, 2012 09:19 AM
yeldarb82
Aug 4, 2009 09:44 PM
05chop
Apr 24, 2008 06:26 PM
