If your referring to the soft hoses you can get the hose at Napa or another parts outfit as long as it's SAE 30r9 or r10 rated. Then cut to size. 3/8' and 5/16'.
Thanx for the info. But also i have 190000 on what i believe to be the orignal injectors should i try to use one of jims kits or just buy some that have been compleatly gone through and rebuilt by a proffecina that really knows what hes looking at?
Jim IS a professional, I would trust his injectors over any name brand stuff, Jim puts his reputation behind every set he builds, just send him your injectors if you are uncertain about your own skills and let him take care of you, and you will not be disappointed
why do you think your injectors are bad?? 190k is not that much on a stock set, do you have a lot of smoke are start up??
No smoke i use to run a 14.7k resistor i ran it for about 4mo then one day it started to miss on cylnders so i took it out and the truck ran fine after but i cant even run a 5k without it happening so i changed the o-rings 3 were bad but i still cant run a resistor anymore i have AE and i cant find anything else wrong with the truck rebuilding them isnt a real big problem for me i am a service tech for a mechanical contractor i just dont want to over look something and have to tear it all back apart to fix it.
