Mpg dropped
Old Jan 28, 2013 | 12:06 AM
rangergirl94's Avatar
rangergirl94
Mpg dropped
I have a 94 2wd 4.0 auto 3.08 rear end it has 195,000 im gettin 15 city 18 hwy I used to pull 24+ hwy I changed plugs and wires no change any ideas? It has the 4.0 tick but its always had it
Old Jan 28, 2013 | 12:40 AM
Furyus1's Avatar
Furyus1
Just a thought, but how cold is it there? Colder weather can sometime make the mileage drop - especially if you spend any time warming the vehicle up...
Old Jan 28, 2013 | 07:43 AM
tomw's Avatar
tomw
I would check pressures. Tire pressure and fuel pressure. With O2 sensors, the air filter will work fine until it's on its last legs, then the system cannot compensate, and mileage suffers. Until then, you just lose power as the fuel:air ratio is kept 'good'.
Do you have E85 fuel? You can lose mpg with the ethanol 'enhanced' fuels. Try a tank of real pure gasoline if you can find it. Have you changed the tire size? Do the brakes drag? When you take your foot off the gas, does the truck slow down quicker than it did before? Do you have neighborhood 'friends' that like to borrow gas from your tank to use in theirs? I've had that happen where the tank was 3/4 full, and next thing I know it was down near empty with very few miles in between.
tom
Old Jan 28, 2013 | 03:20 PM
rangergirl94
Im running 235/75/15 now the mpg dropped slightly from the bigger tires but never this bad and yes its been about 10 degrees here
Old Jan 28, 2013 | 05:22 PM
97ranger xlt's Avatar
97ranger xlt
i know warm up time has dropped my mileage recently when temps are zero - +15 deg F.
that and crappy ethanol laced fuel.
Old Jan 29, 2013 | 05:26 AM
tomw's Avatar
tomw
You might check your thermostat. If it 'leaks', it will cause the engine to take longer to come to full temp, and might even cause it to run cool. Both will affect gas mileage. If the thermostat disc doesn't close tightly, it will allow coolant to leak past the thermostat, slowing heatup.
tom
Old Jan 31, 2013 | 12:37 PM
dybeepvw's Avatar
dybeepvw
Did you go to a different type spark plug or use the exact same kind as the old ones.
Old Jan 31, 2013 | 04:32 PM
97ranger xlt
warm up time effecting gas mileage
ok it was 50 deg F here today and warm up time on same route/speeds was reduced by approx 50% compared to zero deg F. T-stat is fairly new and working. heat is super hot.
temp gauge shows normal when fully warmed up ie. same as in summer.
soo.. my $.02 worth - lower temps = worse gas mileage.
Dutter
Mar 9, 2011 09:21 PM
CraigOutdoors
Modular V10 (6.8l)
Feb 17, 2011 11:55 PM
64dump
1997 - 2003 F150
Jun 25, 2010 06:37 PM
afonda
Feb 26, 2009 12:43 PM
Gary (UT)
1978 - 1996 Big Bronco
May 6, 2004 05:22 PM
