Top End Job
Old Jan 27, 2013 | 08:30 PM
fast crap racing's Avatar
fast crap racing
Top End Job
Just bought an 05 F250. Ordered an EGR delete, head gaskets, and new ARP head studs. I need to know how much time this job will take, any special tools required, and any additional work I should do while the motor is apart.
Old Jan 28, 2013 | 12:17 AM
powerstroke72's Avatar
powerstroke72
Moved to the 6.0L Powerstroke Diesel forum.
Old Jan 28, 2013 | 05:29 AM
mustang_309's Avatar
mustang_309
Before you start a good idea would be too take a scan gauge II and check your ECT/EOT deltas to see the health of your oil cooler or even better yet just install a new oil cooler while you are there. If you do decide to do the oil cooler it is a good idea to do a coolant flush and clean with VC-9 before you get to it. As far as tools go you will need a long t40 torqs bit for the injector hold down bolt and a regular torqs bit set for the rest of the torqs fasteners, a torque wrench that will torq as low as 10 ft/lbs and one that will torque as high as 250 ft/lbs ( for the stud nuts ), you will also need a 10 MM hex bit for the stand pipes and dummy plugs ( you should do the upgraded stand pipes and dummy plugs while you are there and you will need a 12 MM hex bit for the updated plugs and pipes )
Old Jan 28, 2013 | 05:33 AM
mustang_309
Here is a link that Piolet found on youtube when I had the same question
Old Jan 28, 2013 | 05:49 AM
mustang_309
I forgot to mention its also a good time to install the upgraded STC fitting, and clean the turbo.
MaxOut
Mar 3, 2017 08:08 AM
Ford'05HG
Sep 26, 2015 08:15 PM
walrus
Feb 4, 2015 09:33 AM
Sarge261
Jul 13, 2012 06:41 PM
_Me2_
Oct 2, 2011 10:22 AM
