My truck is a 1973 F250 with a 390, 901 cam, "S" Code intake, 600 vac sec. holley, dynomax headers, dual 2 1/4 exhaust into 2 glasspacks, it started smoking wuite abit out of the driver side pipe wuite a bit it always did it alittle more but now it is a considerable amount someone told me i had a bad valve stem seal, I was considering replacing them what do u pro's think?
I pray that it is only that. I had the exact same problem. Turned out to be the C clip that holds the wrist pin in place broke and it scored the cyl. wall really bad. If you start shooting oil out the tail pipe, start praying.
Are you loosing coolent?
White some is usually coolent/oil .
If the engine has not had the stem seals replaced then I would say go for it but I think you may have more problems then just the valve stem seals .
Look at the condition of your spark plugs white looking plugs mean coolent - black with oily depsites is valve guides/rings/ stem seals .
Do a compression test and be sure to post your results here!
if you ask me it sounds like a head gasket. like they said white is usually coolant. if is not the gasket id start checking for warped or craked heads.
Make sure you get a fitting to fit the spark plug hole that you can hook up an air line to. Air up each cylinder with about 60 psi +/- so your valves dont drop down and do each cylinder that way while you are taking off your valve springs. Good Luck !!!!
Hi Guys,
Just a little trick that I have used sucessfully on a few motors when changing valve stem seals or anything else that requires removing the keepers. Instead of pressuring the cylinder with air I just remove the all the plugs crank the engine over by hand until the piston of the cylinder I'm ready to work on is at or near the bottom. I then insert about 1 foot of soft Nylon rope through the spark plug hole and gently turn the engine over by hand until the piston pushes the rope up against the bottom of the valve, holding it in place. Works great, doesn't require any special fittings and is less likely to fail then the air method.
Good luck
That's what I've done as well and you're right...works great and the chances of failure are exactly zero. I'd hate to see that valve stem disappear into the abyss because someone inadvertantly turned off the power to the garage. That'd be a bummer. Our method is low tech, but it works!
