95 F-150 trans problem
Old Jan 27, 2013 | 06:05 AM
V8Ranger302's Avatar
V8Ranger302
I have a friend that has a 95 F-150 5.0 4x4 frankinstine... He was driving it and he lost all forward gears.. Reverse still works fine.. We changed a couple parts, not sure what they are all called, one was where the shift linkage is on the side of the trans, the other was inside the pan, a transmission control solenoid, then changed the filter.. I dont know what this thing has in it for a trans, but the filter kit it calls for wasnt even close ( calls for a 20 bolt pan kit, It has 14 bolts ) . Ended up getting a filter kit for a 97 AWD 5.0 Explorer.. It has a E4OD.. There was no noises or slipping when it quit working.. Is there something else it could be or do you think the trans is just toast???
Old Jan 27, 2013 | 06:25 AM
timbersteel's Avatar
timbersteel
Was the CEL ever on? Has he tried to pull codes? Can be easy to do.
Fuel Injection Technical Library » How To Run a Self-Test
Old Jan 27, 2013 | 11:59 AM
V8Ranger302
no, no check engine light...
Old Jan 28, 2013 | 05:00 AM
V8Ranger302
What do I have for a trans in this thing???? Why is it everything I look up for this has a 20 bolt pan. This has a 14 bolt pan.. Its a 95 but can I put a trans in it from a 97insh?? The only thing I could find that looked like this one is in a AWD explorer. Can you swap the AWD transfur case with a 4x4 one so I can use that trans without having to change the output shaft?
Old Jan 28, 2013 | 08:50 AM
Mddagati's Avatar
Mddagati
Sounds like an Aod nor the newer e4od
reMARKable6965
Aug 11, 2017 02:37 PM
Green Griffin 420
Jan 17, 2013 09:45 AM
water 5
Mar 11, 2006 01:11 PM
Beaned
Aerostar
Feb 20, 2004 11:47 PM
lt
Mar 12, 2001 05:52 PM
