Leaf springs?? Please help!
Old Jan 27, 2013 | 04:57 PM
fordman67's Avatar
fordman67
Bill loved his ttb springs on axle swap.i believe his kidneys are much worse for the wear...
Old Jan 27, 2013 | 05:05 PM
fordman67's Avatar
fordman67
The way I see it you have three options..
1) stock 350 springs used=cheapest
2) stock 350s with rsk for stock a bit more$
3) new v codes and pmr shackle kit....possible best ride =more money
It all just depends on budjet...either way you will need shocks,pitman arm
If you don't have the 350 pitman arm....rsk can have correct one bought at a discount...I'm broke so I understand .I used my stock springs and did the rsk and bilsteins.IF I had bought new springs and wanted the extra lift I would have tried SD springs.I did not want the lift (fit inside my garage door) and am there again...broke...married with children.just do what you can afford.
I can tell you from my experience ANY rsk will be better than the stock spring configuation...sd...I can NOT say...
Old Jan 29, 2013 | 02:16 PM
TireJockey's Avatar
TireJockey
Found a set. Got em from the same guy i got the axle from. $60 for the springs and pitman arm and panhard bracket
Old Jan 29, 2013 | 02:19 PM
TireJockey's Avatar
TireJockey
And yes i know any RSK will be the best. But for now i need to save for 35s, i do plan on doing the 3 inch RSK for stock springs. And the shackle flip in the rear. For a 4inch lift.
Old Jan 30, 2013 | 04:33 AM
Diesel_Brad's Avatar
Diesel_Brad
That will make it WAY high in the rear
Old Jan 30, 2013 | 10:56 AM
TireJockey's Avatar
TireJockey
I dont believe so. For some reason my truck only has 2 inch blocks. Anyone know why? Has the tow package. But the 3 inch rsk in the front and the 4.5 inch shackle flip in the rear and then take out my blocks. And just shim my axle. Thats the plan at least. It will be a 3 inch in the front 2.5 in the rear
Old Jan 30, 2013 | 12:15 PM
fordman67's Avatar
fordman67
I believe 250 should have 3" maybe somebody lowered the rear at some time to level the truck out a bit? Your biggest variable is the condition of the used springs and of course your rears.it may take some tweaking to get it exactly how you want it but you will get there....let us know how it works out! Pics or it didn't happen! Lol
Old Jan 30, 2013 | 03:13 PM
TireJockey's Avatar
TireJockey
Yeah i know. I will always get it the way i need it lol. But i will be posting picks in my Dana 60 rebuild thread along with me an Rob doing a detailed right up of how to do it. And different options people have. And where to buy what parts. Seeing as i am a total of $1050 into my rebuild. And In terms of lifting what options they have! All that good stuff. Should be pretty awesome
Old Jan 30, 2013 | 04:47 PM
Diesel_Brad
F250s have 2 or 2.5" blocks , cant remember
I dint realize you were doing away with the block.
just a FYI, anyone I have seen use the shackle reversal for the rear has had major issues. (driveline angle, axle shoved Forward and driveshaft jammed into the t-case)
Old Jan 30, 2013 | 10:57 PM
ReBilld's Avatar
ReBilld
Yeah, I don't recommend leaving the 250 springs in with the D60 swap. It will beat your teeth out of your mouth!
nick cooper
Nov 1, 2013 05:15 PM
RRranch
Oct 23, 2011 03:39 PM
rideracelivemx7
16
Sep 4, 2009 09:58 PM
ben97
Missouri Chapter
Jan 29, 2007 09:59 PM
Crowbar65
Feb 9, 2003 08:26 AM
