Sponsored by: Auxito
Temperature and compass display
Old Jan 26, 2013 | 04:06 PM
79CAMOFORD's Avatar
79CAMOFORD
My temperature and compass display just died on me, I don't have an owners manual with the truck so I don't know if it's a fuse I need to replace or what I need to do to get it working again. Any help would be greatly appreciated
Old Jan 26, 2013 | 04:37 PM
Bluegrass 7's Avatar
Bluegrass 7
Likely an issue on the circuit board.
There are two surface mount resistors that come loose from solder migration. They normally run very hot with little cooling when closed up in that assembly.
You need to take the Bezel off, then the power plug, then remove the board.
These parts are close to the push bar you use to turn the display on and off so it makes them come loose of the circuit board.
You need a 25 watt hand iron and some small Resin core solder.
All available at a Radio Shack.
Good luck.
ajordan193
Oct 25, 2017 07:07 AM
ranger1999 Bob
1997 - 2003 F150
Mar 5, 2017 12:08 PM
BrockwayMT
Feb 23, 2012 07:00 PM
joenoll
2004 - 2008 F150
Jun 19, 2008 07:37 PM
VodkaMan
Dec 11, 2007 08:27 PM
