For areas in the cold the WHITE diesel kleen bottle is the winter formula, warmer areas will have the grey bottle all year. I add accordingly with every fill up.
I add DK if the expected temps are going to dip below 40 - cheap insurance, gelled fuel isn't much fun. When it gets to be single digits I toss a bottle of DK 911 behind the seat.
It depends where you buy your diesel from. If you buy from a station that moves alot of diesel, you usually should have no problem. Compare to a station that sits on it and sells it at a lower price. I should know I deliver the fuel. Always be pro active and play on safety and use some type of anti-gelling fuel additive. If you live where it gets cold below 32*.
I use Stanadyne and have had no issues, been down as low as -9 recently and have had average highs in the 30's for almost a month. There was a thread on here a while back that had lab test results on several differt products. Stanadyne was in the top 5 or so. Some were better depending on which properties were required. Some were just plain snake oil at best and a couple were actually damaging to the injectors
I personally like the Ford cetain booster with anti gel. I have used standyne, DK, lucas but the Ford is cheapest and seams to work every bit as well....$7 and some change will treat 100 gallons.
I agree with clem1226. I have used the Ford PSD additives as well. Can't beat the quality for the price. The Ford brand also has the long neck bottles that make pouring easy, no funnel required. I have read or been told (Can't remember?) Stanadyne makes this for Ford.
The bottom line is, as long as you use a good quality additive anti-gel if needed, you can't go wrong. It also helps to buy your diesel from a high volume station.
Whatever you choose is up to you, just do some homework because some products don't flip the bill. The key to using any additive is adding it in before the fuel reaches it's cloud point (somewhere around the lower-mid 20 degrees F range). Once the fuel starts to cloud the additive won't be effective (unless you use something like Diesel 911, specifically made to un-gel diesel fuel). You could throw as much as you want in the tank, but it's too late.
was down to -15 F here last week. Been using this with straight #2 diesel for the last 3 winters, no problems with any of our 7.3L's or my families farm equipment.
One of the other main concerns besides fuel gelling and cetain boost is lubrication properties. The ULSD that is required today is not designed for older engines. I don't recall the actual numbers for the "old diesel" but I believe that the sulfur content was in the 100 - 200 PPM range. The new ULSD is like 3 - 6 PPM. Haven't looked for that lab report but my notes show that Opti-Lube XPD has the best lubricating properties of the bunch, and also has a " Summer blend " as well. These and Stanadyne are a little spendy, but what is a couple of extra cents per mile when you are looking at new injectors for no other reason?
Mike
We plow snow at work during the winter months, and it has been a steady high of less than 10*f for around a month, and we haven't had a gelling problem on 13 machines and four transfer tanks with filters. We have used Howes for the last three years that I have worked there without a single gelling problem. If someone has a breakdown or a problem, I'm the one they call. Before I got there, we used DK white bottle, and had a few issues with gelling, but it defiantly helped. We learned that DK has alcohol, which dries out the already dry ULSD, and Howes does not.
