Replacing gear shift collar
Old Jan 26, 2013 | 10:18 AM
bigjake628's Avatar
bigjake628
Once I get the steering wheel off how do I remove the hazard/blinker to get to the collar?
Old Jan 26, 2013 | 10:21 AM
bigjake628's Avatar
bigjake628
This is the wire cluster that runs up to the blinker/hazard/horn. There is no plug except under the dash. Do I have to actually cut the wire and splice or is there a trick I don know about?
Old Jan 26, 2013 | 10:22 AM
bigjake628's Avatar
bigjake628
I see the nuts at 12 and 6 that I have to loosen to get to the collar but how would I get the new one on?
Old Jan 26, 2013 | 11:46 AM
410 Highboy's Avatar
410 Highboy
I went through this . Look for the thread . I had a lot of good help .
Old Jan 26, 2013 | 11:57 AM
bigjake628's Avatar
bigjake628
*Edit* don't be a dummy like me and release the pins on the harness and pull the wires through the column
The only way that I could figure to remove the blinker/hazard/horn assembly was to remove the connector under the dash and pull the wire so I had room to get it off. Make sure your wires have a way to match them back up.
Buy some connectors
and heat shrink for later
this is the back side of the shift collar note the notch inside. There is nothing wrong with this one but since I already got the new one I will use the new one.
This is the shift tube or whatever it is called. Look at the hole and the weld marks. A piece fell off as I was pulling the shift collar off and I was like "wtf" was that thank god it fell I'm the floor board and not down the tube. Be careful when you pull off the collar.
This is the piece that fell off and it was tack welded to the shift tube this is what sit in the notch in the shift collar this allows you to turn the shift tube and put into drive reverse ect. I have to weld this back on the tube. I guess I will have to drill out the two oval notches and weld there because there is no room to have a weld bead along the sides and front of the piece. I will try to take pictures of that process as soon as I get some gas for my welder.
Old Jan 26, 2013 | 12:06 PM
VocaTexas's Avatar
VocaTexas
Sorry I didn't see this earlier...
Looks as if you went ahead and cut the wiring. There is another (recommended) method. When you unplug the wiring you can take a red piece out of the connector. This allows you access to push-pins that release the individual wires from the plug. You use the wiring to pull a string or small gauge wire up through the column. Replace the switch, then use the pulled wire to pull the new wiring back down the column. Re-attach wires to the plug, then plug back into the harness. It's not all that hard to do, and eliminates the possibility of bad connections due to splices in the wiring.
In the later large columns you don't have to fish the wiring through the column, just on the pre-78s.
Old Jan 26, 2013 | 12:11 PM
bigjake628's Avatar
bigjake628
Lol I wish you would have seen it earlier too lol. I didn't think of that.
460me's Avatar
460me
You release the pins from the connector(it's there look for it) and slide the wires/harness through the column.
Old Jan 26, 2013 | 01:10 PM
mikeo0o0o0's Avatar
mikeo0o0o0
Look into the plug, there is a red plastic wedge. Pull the wedge out, each wire has a little plastic finger that holds the terminal in place. Use a small screw driver, punch, awl or even a nail push the finger away from the terminal and pull the wire out of the plug.
To reinstall them just push the wire back in until the finger locks it in place then reinstall the red wedge.
A couple of things, make a chart of which wire goes where and tie a strong piece of string or wire to the end of the wiring so when you pull it through the column you can use the wire to pull it back through.
Idaho Highboy
22
Mar 30, 2022 12:30 AM
Dennis-
Jul 22, 2018 03:41 AM
little_mule
May 22, 2012 08:24 AM
g0dl355
Oct 24, 2009 11:48 PM
SpankF100
Jan 7, 2005 04:26 PM
